- Thank you received: 127
Think you found a bug there.tecno wrote: Hmmm looking at .comp we have this
case 1: // Gear E
gear = (high_gear != 0) ? 5 : 10;
break;
Should it not be like this then? Hi gear is 5 and Lo gear is 10 right?
setp gearblocker.0.gear.10.min-speed 80
Sure somebody will correct us
tecno wrote: Is this correct?
Code:#GearShift Lo # E gear setp gearblocker.0.gear-E.min-speed 80 setp gearblocker.0.gear-E.max-speed 160 setp gearblocker.0.gear-E.ratio 0.064 # D gear setp gearblocker.0.gear-D.min-speed 160 setp gearblocker.0.gear-D.max-speed 270 setp gearblocker.0.gear-D.ratio 0.108 # C gear setp gearblocker.0.gear-C.min-speed 270 setp gearblocker.0.gear-C.max-speed 450 setp gearblocker.0.gear-C.ratio 0.18 # B gear setp gearblocker.0.gear-B.min-speed 450 setp gearblocker.0.gear-B.max-speed 750 setp gearblocker.0.gear-B.ratio 0.3 # A gear setp gearblocker.0.gear-A.min-speed 750 setp gearblocker.0.gear-A.max-speed 1250 setp gearblocker.0.gear-A.ratio 0.5 #GearShift Hi #B gear setp gerablocker.0.high_gear.gear-B.min-speed 1250 setp gerablocker.0.high_gear.gear-B.max-speed 11500 setp gearblocker.0.high_gear.gear-B.ratio 0.6 #A gear setp gerablocker.0.high_gear.gear-A.min-speed 1250 setp gerablocker.0.high_gear.gear-A.max-speed 11500 setp gearblocker.0.high_gear.gear-A.ratio 1
