extra spindle on 7i76e + Spin x1
9 years 1 month ago - 9 years 1 month ago #99417 by tecno
forum.linuxcnc.org/10-advanced-configura...y-high-speed-spindle
Looks like I asked the question as wrong topic. Hopefully somebody can answer how to get the spindle working.
Cheers
Bengt
Last edit: 9 years 1 month ago by tecno.
9 years 1 month ago #99466 by tecno
Peter, is it possible to get my secondary spindle running with Spinx1? 7i76e_7i76x1_7i85sx1D.bit is used now.
Cheers
Bengt
9 years 1 month ago #99469 by PCW
Probably, What you would need is a config that steals one of the 7I85S's step dir outputs and uses it for
PWM, Ideally you would have 3 outputs (PWM/DIR/ENA) free for the SPINX1
Another option is to use one of those inexpensive Chines 5 axis breakout boards with Analog out:
www.ebay.com/i/152695794698?rt=nc
and connect it to the unused 7I76e expansion connector
9 years 1 month ago #99470 by tecno
OK thanks Peter,
How would this be done in HAL for this secondary spindle?
El-cheapo is OK with me need only to have start stop and variable speed for the spindle.
9 years 1 month ago #99735 by tecno
Peter, can you share some knowledge on how to implement this in HAL
9 years 1 month ago #99738 by PCW
This requires a custom bit file that has a PWM generator (perhaps on the second expansion connector)
hal wise It requires setting up the PWM generators scaling to match the spindles RPM ay full speed and the
PWMs, mode and frequency to what the SPINX1 needs (man hostmot2)
Time to create page: 0.265 seconds
