5i25 configuration with only a G540, no daughterboards
  • mpicco
  • Topic Author
  • New Member
  • New Member
8 years 9 months ago #104220 by mpicco
Got a used MaxCNC 10 for Christmas and am trying to get it running with LinuxCNC. The PC has a Mesa 5i25 board and I have that connected to the G540. The PC is running the latest LinuxCNC (Debian).
The only thing I understand thus far is that pncconf is required to setup the 5i25 with the G540, however, it's less than intuitive to this newbie. Is there a known list of steps I can work through to get this operational?
Thanks in advance!
Michael
8 years 9 months ago #104222 by cmorley
Unfortunately Pncconf doesn't come with this firmware installed by default.
I'll see if i can dig one up then i'll tell you how to add it - unless someone has a sample config to give you.
Chris M
8 years 9 months ago #104223 by cmorley
ok here is the firmware XML file for pncconf.
it needs to go in the /lib/firmware/hm2/5i25 folder
You need to use sudo to do that.
Then when you run pncconf there should be two options on the mesa configure page under board name - internal data 5i25 and 5i25
Select 5i25 and you should see g540x2 undoer firmware.
hit accept component changes button.
depending on what connector your are using stepgen 4 or 9 must be set as a charge pump.
confirgure the rest as you see fit.
Hopefully that is clear enough and I didn't miss anything...
Chris M
The following user(s) said Thank You: mpicco, mac44mag
  • mpicco
  • Topic Author
  • New Member
  • New Member
8 years 9 months ago #104226 by mpicco
Thank you, Chris!
That brings up the g540x2 as a selection. When I hit the "accept component changes" button, two more tabs appear: "I/O Connector 2" and "I/O Connector 3". Each of those has a column marked "Num", which I assume to be the actual pin numbers for my 25-pin cable running to the G540. Having only ever worked with stepperconfig in the past, I'm guessing that I set these pins as I would with stepperconfig? Looking at pin #2 (for instance), I'd want to set that as X Step and set pin #3 to X Direction, but those terms aren't appearing in the drop-down. The terminology seems to have changed when going from one config program to the other.
I feel a lot closer than I've been so far and really appreciate the help!
8 years 9 months ago #104227 by cmorley
unfortunately the numbers in pncconf represent the component (or channel) number not the connector pin number.
This might help:
Configuration pin-out: IO Connections for P3 Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir 1 0 IOPort None 14 1 IOPort PWMGen 0 PWM (Out) 2 2 IOPort StepGen 0 Step (Out) 15 3 IOPort None 3 4 IOPort StepGen 0 Dir (Out) 16 5 IOPort StepGen 4 Step (Out) 4 6 IOPort StepGen 1 Step (Out) 17 7 IOPort None 5 8 IOPort StepGen 1 Dir (Out) 6 9 IOPort StepGen 2 Step (Out) 7 10 IOPort StepGen 2 Dir (Out) 8 11 IOPort StepGen 3 Step (Out) 9 12 IOPort StepGen 3 Dir (Out) 10 13 IOPort QCount 0 Quad-A (In) 11 14 IOPort QCount 0 Quad-B (In) 12 15 IOPort QCount 0 Quad-IDX (In) 13 16 IOPort None IO Connections for P2 Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir 1 17 IOPort None 14 18 IOPort PWMGen 1 PWM (Out) 2 19 IOPort StepGen 5 Step (Out) 15 20 IOPort None 3 21 IOPort StepGen 5 Dir (Out) 16 22 IOPort StepGen 9 Step (Out) 4 23 IOPort StepGen 6 Step (Out) 17 24 IOPort None 5 25 IOPort StepGen 6 Dir (Out) 6 26 IOPort StepGen 7 Step (Out) 7 27 IOPort StepGen 7 Dir (Out) 8 28 IOPort StepGen 8 Step (Out) 9 29 IOPort StepGen 8 Dir (Out) 10 30 IOPort QCount 1 Quad-A (In) 11 31 IOPort QCount 1 Quad-B (In) 12 32 IOPort QCount 1 Quad-IDX (In) 13 33 IOPort None
In pncconf one only selects the stepgen no need to select step and direction (thats becuse you can't change their location like in stepconf)
  • mpicco
  • Topic Author
  • New Member
  • New Member
8 years 9 months ago #104506 by mpicco
If I'm understanding the list of P2/P3 connections, this is what I'm thinking my pncconf Mesa card config page should be:
Boardname: 5i25
Firmware: g540x2
These two selections result in:
PWM Base Freq: 20000 Hz.
PDM Base Freq: 6000000 Hz.
# of Encoders: 2
# of PWM Generators: 2
# of Step Generators: 10
# of Pins: 34
The G540 DB-25 pinout tells me X-Step is pin 2; Y-Step is pin 4 and Z-Step is pin 6.
Understanding that I only choose the step and not direction, how do I apply the chart you made above to properly choose the assignments of X, Y & Z axis? Assuming the column marked "Pin#" refers to the DB-25, would I put X-axis Stepgen on "Num 2", Y-axis Stepgen on "Num 6" and Z-axis Stepgen on "Num 9"?
8 years 9 months ago #104509 by PCW
normally you would assign
stepgen 0 to the X axis
stepgen 1 to the Y axis
stepgen 2 to the Z axis
pncconf doesn't use pin numbers at all
  • mpicco
  • Topic Author
  • New Member
  • New Member
8 years 9 months ago #104522 by mpicco
Looking at the tabs "I/O Connector 2" and "I/O Connector 3", I don't see a choice of "stepgen 0", etc. The columns are "Num", "Function", "Pin type" and a check box to invert the signal. This is getting confusing!
8 years 9 months ago #104523 by PCW
So on I/O connector 3 you should see a selection box named "Unused Stepgen" with a "Num" of 0
select "X Axis Stepgen" for this...
  • mpicco
  • Topic Author
  • New Member
  • New Member
8 years 9 months ago #104525 by mpicco
I've now at least gotten a response on the X axis! The motor mostly just sits there and vibrates a little in each direction when I attempt to 'jog' it. What setting might I check?
Time to create page: 0.066 seconds
