PNCconf does not start
8 years 9 months ago - 8 years 9 months ago #104236 by kibo
PNCconf does not start was created by kibo
Hi
I already have a LinuxCNC configuration. It works.
But I can not run the PNCconf wizard. Immediately after the start i got the message (attachment).
The gif (/usr/share/linuxcnc/linuxcnc-wizard.gif) is ok.
GError:Unable to recognize image format in file "/usr/share/linuxcnc/linuxcnc-wizard.gif"
I've updated my system.
I instaled: PyCam, Inkscape, pstoedit
Tomas
Last edit: 8 years 9 months ago by kibo. Reason: correction
8 years 9 months ago #104239 by cmorley
Replied by cmorley on topic PNCconf does not start
I've never seen this error. i assume you opened the gif and it's fine (you inferred this).
What version of linuxcnc are you using?
It must have worked at some time ? (you have other pncconf questions)
If it worked before and you haven't tinkered with pncconf or the gif that leads me to wonder about hardware problems.
Chris M
8 years 9 months ago - 8 years 9 months ago #104240 by kibo
Replied by kibo on topic PNCconf does not start
"i assume you opened the gif and it's fine"
Yes, file is ok.
"What version of linuxcnc are you using?"
2.7.11
"It must have worked at some time ?"
PNCconf wizard worked. I used it for setting my machine.
8 years 9 months ago #104241 by cmorley
So that makes it hard to diagnose.
Need to know what changed between it working and not (which i'm sure is lots)
hard to say for sure but seems related to your system rather then pncconf it's self.
You could try using a different gif (place it in same folder and rename it)
If any other info comes available please post back.
Chris M
The following user(s) said Thank You: kibo
8 years 9 months ago #104284 by kibo
Hi
today morning I updated my computer and after that the PNCconf wizard started to work.
Tomas
8 years 9 months ago - 8 years 9 months ago #104355 by bluephoenix
Replied by bluephoenix on topic PNCconf does not start
Hi there,
I am facing the same problem, but my computer is up to date. I am also using 2.7.11 and the file is o.k. I have a feeling that is has something to do with python, but I am not sure. Does anybody have an idea.
Regards,
Albert
Last edit: 8 years 9 months ago by bluephoenix. Reason: error message added
Time to create page: 0.121 seconds
