hm2_pci.ko issue
8 years 6 months ago #108668 by TRAUPMANN00
hm2_pci.ko issue was created by TRAUPMANN00
Designed and built my own CNC router 3 axis bridge 48"x48"x10" gantry with Nema34 steppers. LINUXCNC is at 2.8.0-pre1-3695-g159ce9c. All the lights are on, but nobody is at home!
I've muddled my way up to and through PnCConf, but LinuxCNC won't run due to: "Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/hm2_pci.ko: No such device" I've configured PnCConf several ways, but always end with this error.
(FYI I'm an old fart, a bit rusty or fuzzy at Linux, it's been 8 years since I've touched Unix. Looking for 2nd childhood).
The file exists, so I'm not sure if what is in the hm2_pci.ko file is the issue, or I need to set or add some parameter to a different value or this is just a default issue and I'm in deep dodo!.
File Name: gantry008-hal.txt
File Size:11.69 KB
File Name: gantry008-ini.txt
File Size:4.44 KB
File Name: ErrorFile20180407.txt
File Size:80.37 KB
8 years 6 months ago #108686 by PCW
Replied by PCW on topic hm2_pci.ko issue
It looks like the 5I25 card is not found
what is the result of
lspci -v
8 years 6 months ago #108702 by TRAUPMANN00
Replied by TRAUPMANN00 on topic hm2_pci.ko issue
looks like you are right, please check this output.
File Name: pci.txt
File Size:4.78 KB
8 years 6 months ago #108703 by TRAUPMANN00
did the obvious: changed pci location with 5i25. the appropriate lights blinked, but ...
File Name: pci2.txt
File Size:4.78 KB
looks like still no reply from the 5i25, ((nothing Mesa or 5i25 -- what should I see??
8 years 6 months ago #108730 by PCW
Yeah, no sign of the 5I25, so either bad MB, bad 5I25, dirty slots, low 3.3V etc,
no easy way to tell. (well low 3.3V would mean 5I25s red LEDS stay on after power up)
Time to create page: 0.353 seconds
