I think I'm in over my head.
  • Catch22
  • Topic Author
  • Elite Member
  • Elite Member
8 years 2 months ago - 8 years 2 months ago #116887 by Catch22
I think I'm in over my head. was created by Catch22
Well I just bought a 3 axis knee mill with an Anilam Crusader M control that no longer works, so I bought the Mesa 5i25 and 7i77 to use with it. I am going to to use the existing servo drives and SEM servo motors. I have setup machines on mach3 using stepper motors and four d it to be fairly easy to do. But reading about Linux and using a closed loop I thought this would be the best way to go. Unfortunately Linux is a bit harder to figure out. Anyways I have the 5i25 and 7i77 hooked up and tried the pncconf and when I was done it wouldn't open. If anyone could possibly help me out I would be very appreciative.
Thanks Mike
Last edit: 8 years 2 months ago by Catch22. Reason: Left out a few details
8 years 2 months ago #116903 by Clive S
Replied by Clive S on topic I think I'm in over my head.
What wouldn't open?
For a start I would post the ini and hal files from your config folder.
The following user(s) said Thank You: Catch22
8 years 2 months ago #116908 by bevins
Replied by bevins on topic I think I'm in over my head.
First off, those usually have SEM DC Servos, so govern yourself accordingly because the 7i77 is +-10V.
Depends of the drivers if you can use the 7i77.
The 5i25 and 7i77 is the easiest set of cards to setup and run.
1. Make sure you have 5v jumpers setup correctly on the 5i25 and 7i77, whether you have the PC providing the 5v or external 5v.
2. Make sure you have field voltage connected correctly, (see the 7i77 manual).
3. pncconf does a good job on the 5i25 / 7i77 config. Do a simple basic config with pncconf then manually edit the config files to suit your needs.
You are going to need to provide more info than "it wouldn't open". Please provide the details of the error messages.
Also you might want to post your hal and ini files.
Regards,
Bob
8 years 1 month ago #117146 by andypugh
Replied by andypugh on topic I think I'm in over my head.
Catch22 wrote: tried the pncconf and when I was done it wouldn't open. If anyone could possibly help me out I would be very appreciative.
Well, it would be odd for PnCConf to create a config that wasn't correct, so the most likely problem is that the 7i77 smart-serial section is not reporting for duty, so some HAL pins that PnCConf expects to see are not present.
Can you paste the error report into a reply? There is a "select all" button on the error dialog, and then Ctrl-C will copy the text.
Typically you see this problem if the 7i77 field-IO section is not powered. So make sure that you have field-power connected. That IO section has a small processor that is powered from the field power.
  • Catch22
  • Topic Author
  • Elite Member
  • Elite Member
8 years 1 month ago #117586 by Catch22
Replied by Catch22 on topic I think I'm in over my head.
My computers motherboard burnt out so Im on hold till I fix it.I appreciate all the comments so far and will get back to it very soon.
Thanks Mike
  • Catch22
  • Topic Author
  • Elite Member
  • Elite Member
8 years 3 weeks ago #118547 by Catch22
OK wasn't the motherboard, the 5i25 wasn't in the pci slot correctly. Now I have been reading some other posts and I forgot to say that I first bought the Mesa 5i25 and 7i76, but then decided to go with the 7i77, would the firmware in the 5i25 need to be updated to be compatible with the 7i77.
Thanks Mike
8 years 3 weeks ago #118549 by Todd Zuercher
Replied by Todd Zuercher on topic I think I'm in over my head.
Yes
  • Catch22
  • Topic Author
  • Elite Member
  • Elite Member
8 years 3 weeks ago #118569 by Catch22
Ok still having problems with linuxcnc not opening so here is the error report,any help would really be appreciated,I have been trying stuff for days now.
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.14
Machine configuration directory is '/home/mike/linuxcnc/configs/DELTA_CNC_MILL'
Machine configuration file is 'DELTA_CNC_MILL.ini'
INIFILE=/home/mike/linuxcnc/configs/DELTA_CNC_MILL/DELTA_CNC_MILL.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./DELTA_CNC_MILL.hal
Running HAL shutdown script
Killing task linuxcncsvr, PID=3933
Debug file information:
Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/hm2_pci.ko: Invalid parameters
./DELTA_CNC_MILL.hal:8: exit value: 1
./DELTA_CNC_MILL.hal:8: insmod for hm2_pci failed, returned -1
See the output of 'dmesg' for more information.
3933
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] Disabled fast string operations
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000007f5ffc00 (usable)
[ 0.000000] BIOS-e820: 000000007f5ffc00 - 000000007f601c00 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000007f603c00 - 0000000080000000 (reserved)
[ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fed00400 (reserved)
[ 0.000000] BIOS-e820: 00000000fed20000 - 00000000feda0000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fef00000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.3 present.
[ 0.000000] DMI: Dell Inc. OptiPlex 745 /0HR330, BIOS 2.4.1 08/21/2007
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x7f5ff max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask 000000000 write-back
[ 0.000000] 1 base 07F800000 mask FFF800000 uncachable
[ 0.000000] 2 base 07F700000 mask FFFF00000 uncachable
[ 0.000000] 3 base 080000000 mask F80000000 uncachable
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 000000007f700000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] found SMP MP-table at [c00fe710] fe710
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 36524000 - 3728a000
[ 0.000000] ACPI: RSDP 000febf0 00024 (v02 DELL )
[ 0.000000] ACPI: XSDT 000fce97 0006C (v01 DELL B8K 00000014 ASL 00000061)
[ 0.000000] ACPI: FACP 000fcfbf 000F4 (v03 DELL B8K 00000014 ASL 00000061)
[ 0.000000] ACPI: DSDT fff68958 0475F (v01 DELL dt_ex 00001000 INTL 20050624)
[ 0.000000] ACPI: FACS 7f5ffc00 00040
[ 0.000000] ACPI: SSDT fff6d1d6 000AA (v01 DELL st_ex 00001000 INTL 20050624)
[ 0.000000] ACPI: APIC 000fd0b3 00092 (v01 DELL B8K 00000014 ASL 00000061)
[ 0.000000] ACPI: BOOT 000fd145 00028 (v01 DELL B8K 00000014 ASL 00000061)
[ 0.000000] ACPI: ASF! 000fd16d 00092 (v32 DELL B8K 00000014 ASL 00000061)
[ 0.000000] ACPI: MCFG 000fd1ff 0003E (v01 DELL B8K 00000014 ASL 00000061)
[ 0.000000] ACPI: HPET 000fd23d 00038 (v01 DELL B8K 00000014 ASL 00000061)
[ 0.000000] ACPI: TCPA 000fd499 00032 (v01 DELL B8K 00000014 ASL 00000061)
[ 0.000000] ACPI: SLIC 000fd275 00176 (v01 DELL B8K 00000014 ASL 00000061)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 1150MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0007f5ff
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0007f5ff
[ 0.000000] On node 0 totalpages: 521614
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f5534200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 2301 pages used for memmap
[ 0.000000] HighMem zone: 292100 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x05] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x07] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x05] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x06] lapic_id[0x01] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x07] lapic_id[0x02] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x08] lapic_id[0x03] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high level lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x08] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] SMP: Allowing 8 CPUs, 6 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 80000000 (gap: 80000000:60000000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f7769000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 517537
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=737fbe2d-c410-4de9-8c31-460cf9022382 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 4173688 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0007f5ff)
[ 0.000000] Memory: 2045084k/2086908k available (3495k kernel code, 41372k reserved, 1237k data, 416k init, 1177604k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:744 16
[ 0.000000] CPU 0 irqstacks, hard=f5006000 soft=f5008000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2127.938 MHz processor.
[ 0.004003] Calibrating delay loop (skipped), value calculated using timer frequency.. 4255.87 BogoMIPS (lpj=8511752)
[ 0.004008] pid_max: default: 32768 minimum: 301
[ 0.004058] Security Framework initialized
[ 0.004063] AppArmor: AppArmor disabled by boot time parameter
[ 0.004083] Mount-cache hash table entries: 512
[ 0.008111] Initializing cgroup subsys cpuacct
[ 0.008114] Initializing cgroup subsys memory
[ 0.008125] Initializing cgroup subsys devices
[ 0.008127] Initializing cgroup subsys freezer
[ 0.008130] Initializing cgroup subsys net_cls
[ 0.008132] Initializing cgroup subsys blkio
[ 0.008140] Initializing cgroup subsys perf_event
[ 0.008168] Disabled fast string operations
[ 0.008172] CPU: Physical Processor ID: 0
[ 0.008174] CPU: Processor Core ID: 0
[ 0.008177] mce: CPU supports 6 MCE banks
[ 0.008184] CPU0: Thermal monitoring enabled (TM2)
[ 0.008242] ACPI: Core revision 20120320
[ 0.136055] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.136409] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.176390] CPU0: Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz stepping 02
[ 0.180010] Performance Events: PEBS fmt0-, 4-deep LBR, Core2 events, Intel PMU driver.
[ 0.180010] PEBS disabled due to CPU errata.
[ 0.180010] ... version: 2
[ 0.180010] ... bit width: 40
[ 0.180010] ... generic registers: 2
[ 0.180010] ... value mask: 000000ffffffffff
[ 0.180010] ... max period: 000000007fffffff
[ 0.180010] ... fixed-purpose events: 3
[ 0.180010] ... event mask: 0000000700000003
[ 0.188388] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.200037] CPU 1 irqstacks, hard=f5114000 soft=f5116000
[ 0.200041] Booting Node 0, Processors #1
[ 0.008000] Initializing CPU#1
[ 0.008000] Disabled fast string operations
[ 0.212045] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.212093] Brought up 2 CPUs
[ 0.212097] Total of 2 processors activated (8511.75 BogoMIPS).
[ 0.213211] devtmpfs: initialized
[ 0.213211] PM: Registering ACPI NVS region [mem 0x7f5ffc00-0x7f601bff] (8192 bytes)
[ 0.213211] Dell OptiPlex 745 series board detected. Selecting BIOS-method for reboots.
[ 0.213211] dummy:
[ 0.213211] NET: Registered protocol family 16
[ 0.213211] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.213211] ACPI: bus type pci registered
[ 0.213211] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.213211] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.213211] PCI: Using MMCONFIG for extended config space
[ 0.213211] PCI: Using configuration type 1 for base access
[ 0.216092] bio: create slab <bio-0> at 0
[ 0.216142] ACPI: Added _OSI(Module Device)
[ 0.216142] ACPI: Added _OSI(Processor Device)
[ 0.216142] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.216142] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.217256] ACPI: EC: Look up EC in DSDT
[ 0.245971] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[ 0.265067] ACPI Warning: Incorrect checksum in table [TCPA] - 0x00, should be 0x89 (20120320/tbutils-323)
[ 0.265278] ACPI: Interpreter enabled
[ 0.265296] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.265334] ACPI: Using IOAPIC for interrupt routing
[ 0.378464] ACPI: ACPI Dock Station Driver: 1 docks/bays found
[ 0.378473] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.386466] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.403555] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.403555] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.403555] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.403555] pci_root PNP0A03:00: host bridge window [mem 0x000c0000-0x000effff] (ignored)
[ 0.403555] pci_root PNP0A03:00: host bridge window [mem 0x000f0000-0x000fffff] (ignored)
[ 0.403555] pci_root PNP0A03:00: host bridge window [mem 0xf0000000-0xfec00000] (ignored)
[ 0.403555] pci_root PNP0A03:00: host bridge window [mem 0x80000000-0xdfffffff] (ignored)
[ 0.403555] pci_root PNP0A03:00: host bridge window [mem 0xff980800-0xff980bff] (ignored)
[ 0.403555] pci_root PNP0A03:00: host bridge window [mem 0xff97c000-0xff97ffff] (ignored)
[ 0.403555] pci_root PNP0A03:00: host bridge window [mem 0xfed20000-0xfed9ffff] (ignored)
[ 0.403555] PCI: root bus 00: using default resources
[ 0.403555] PCI host bridge to bus 0000:00
[ 0.403555] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.403555] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[ 0.403555] pci 0000:00:00.0: [8086:2990] type 00 class 0x060000
[ 0.403555] pci 0000:00:01.0: [8086:2991] type 01 class 0x060400
[ 0.403555] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.403555] pci 0000:00:02.0: [8086:2992] type 00 class 0x030000
[ 0.403555] pci 0000:00:02.0: reg 10: [mem 0xfea00000-0xfeafffff]
[ 0.403555] pci 0000:00:02.0: reg 18: [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.403555] pci 0000:00:02.0: reg 20: [io 0xecb8-0xecbf]
[ 0.403555] pci 0000:00:02.1: [8086:2993] type 00 class 0x038000
[ 0.403555] pci 0000:00:02.1: reg 10: [mem 0xfeb00000-0xfebfffff]
[ 0.403555] pci 0000:00:1a.0: [8086:2834] type 00 class 0x0c0300
[ 0.403555] pci 0000:00:1a.0: reg 20: [io 0xff20-0xff3f]
[ 0.403555] pci 0000:00:1a.1: [8086:2835] type 00 class 0x0c0300
[ 0.403555] pci 0000:00:1a.1: reg 20: [io 0xff00-0xff1f]
[ 0.403555] pci 0000:00:1a.7: [8086:283a] type 00 class 0x0c0320
[ 0.403555] pci 0000:00:1a.7: reg 10: [mem 0xfe9fbc00-0xfe9fbfff]
[ 0.403555] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[ 0.403555] pci 0000:00:1b.0: [8086:284b] type 00 class 0x040300
[ 0.403555] pci 0000:00:1b.0: reg 10: [mem 0xfe9fc000-0xfe9fffff 64bit]
[ 0.403555] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.403555] pci 0000:00:1c.0: [8086:283f] type 01 class 0x060400
[ 0.403555] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.403555] pci 0000:00:1c.4: [8086:2847] type 01 class 0x060400
[ 0.403555] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 0.403555] pci 0000:00:1d.0: [8086:2830] type 00 class 0x0c0300
[ 0.403555] pci 0000:00:1d.0: reg 20: [io 0xff80-0xff9f]
[ 0.403555] pci 0000:00:1d.1: [8086:2831] type 00 class 0x0c0300
[ 0.403555] pci 0000:00:1d.1: reg 20: [io 0xff60-0xff7f]
[ 0.403555] pci 0000:00:1d.2: [8086:2832] type 00 class 0x0c0300
[ 0.403555] pci 0000:00:1d.2: reg 20: [io 0xff40-0xff5f]
[ 0.403555] pci 0000:00:1d.7: [8086:2836] type 00 class 0x0c0320
[ 0.403555] pci 0000:00:1d.7: reg 10: [mem 0xff980800-0xff980bff]
[ 0.403555] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.403555] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.403555] pci 0000:00:1f.0: [8086:2810] type 00 class 0x060100
[ 0.403555] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0c00 (mask 007f)
[ 0.403555] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 2 PIO at 00e0 (mask 0007)
[ 0.403555] pci 0000:00:1f.2: [8086:2820] type 00 class 0x01018f
[ 0.404038] pci 0000:00:1f.2: reg 10: [io 0xfe00-0xfe07]
[ 0.404047] pci 0000:00:1f.2: reg 14: [io 0xfe10-0xfe13]
[ 0.404056] pci 0000:00:1f.2: reg 18: [io 0xfe20-0xfe27]
[ 0.404066] pci 0000:00:1f.2: reg 1c: [io 0xfe30-0xfe33]
[ 0.404075] pci 0000:00:1f.2: reg 20: [io 0xfec0-0xfecf]
[ 0.404084] pci 0000:00:1f.2: reg 24: [io 0xecc0-0xeccf]
[ 0.404109] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.404124] pci 0000:00:1f.3: [8086:283e] type 00 class 0x0c0500
[ 0.404137] pci 0000:00:1f.3: reg 10: [mem 0xfe9fbb00-0xfe9fbbff]
[ 0.404167] pci 0000:00:1f.3: reg 20: [io 0xece0-0xecff]
[ 0.404202] pci 0000:00:1f.5: [8086:2825] type 00 class 0x010185
[ 0.404217] pci 0000:00:1f.5: reg 10: [io 0xfe40-0xfe47]
[ 0.404226] pci 0000:00:1f.5: reg 14: [io 0xfe50-0xfe53]
[ 0.404235] pci 0000:00:1f.5: reg 18: [io 0xfe60-0xfe67]
[ 0.404245] pci 0000:00:1f.5: reg 1c: [io 0xfe70-0xfe73]
[ 0.404254] pci 0000:00:1f.5: reg 20: [io 0xfed0-0xfedf]
[ 0.404263] pci 0000:00:1f.5: reg 24: [io 0xecd0-0xecdf]
[ 0.404287] pci 0000:00:1f.5: PME# supported from D3hot
[ 0.404328] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.404334] pci 0000:00:01.0: bridge window [mem 0xfe800000-0xfe8fffff]
[ 0.404379] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.404386] pci 0000:00:1c.0: bridge window [mem 0xfe700000-0xfe7fffff]
[ 0.404459] pci 0000:03:00.0: [14e4:167a] type 00 class 0x020000
[ 0.404485] pci 0000:03:00.0: reg 10: [mem 0xfe6f0000-0xfe6fffff 64bit]
[ 0.404589] pci 0000:03:00.0: PME# supported from D3hot D3cold
[ 0.412044] pci 0000:00:1c.4: PCI bridge to [bus 03-03]
[ 0.412052] pci 0000:00:1c.4: bridge window [mem 0xfe600000-0xfe6fffff]
[ 0.412096] pci 0000:04:00.0: [2718:5125] type 00 class 0x110000
[ 0.412114] pci 0000:04:00.0: reg 10: [mem 0xfe5f0000-0xfe5fffff]
[ 0.412231] pci 0000:00:1e.0: PCI bridge to [bus 04-04] (subtractive decode)
[ 0.412239] pci 0000:00:1e.0: bridge window [mem 0xfe500000-0xfe5fffff]
[ 0.412248] pci 0000:00:1e.0: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.412252] pci 0000:00:1e.0: bridge window [mem 0x00000000-0xffffffff] (subtractive decode)
[ 0.412284] pci_bus 0000:00: on NUMA node 0
[ 0.412289] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.413124] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI4._PRT]
[ 0.413770] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI2._PRT]
[ 0.414190] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
[ 0.414557] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI5._PRT]
[ 0.414963] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 1.943124] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 15)
[ 1.943934] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[ 1.944740] ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 5 6 7 9 10 11 12 15)
[ 1.945533] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[ 1.946343] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 *9 10 11 12 15)
[ 1.947136] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[ 1.947934] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 *9 10 11 12 15)
[ 1.948743] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[ 1.948986] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 1.948986] vgaarb: loaded
[ 1.948986] vgaarb: bridge control possible 0000:00:02.0
[ 1.948986] PCI: Using ACPI for IRQ routing
[ 1.955295] PCI: pci_cache_line_size set to 64 bytes
[ 1.955382] reserve RAM buffer: 000000000009fc00 - 000000000009ffff
[ 1.955386] reserve RAM buffer: 000000007f5ffc00 - 000000007fffffff
[ 1.955559] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 1.955566] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 1.957143] Switching to clocksource hpet
[ 1.957213] pnp: PnP ACPI init
[ 1.957227] ACPI: bus type pnp registered
[ 1.965375] pnp 00:00: [bus 00-ff]
[ 1.965379] pnp 00:00: [io 0x0cf8-0x0cff]
[ 1.965383] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 1.965385] pnp 00:00: [io 0x0d00-0xffff window]
[ 1.965389] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 1.965391] pnp 00:00: [mem 0x000c0000-0x000effff window]
[ 1.965394] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[ 1.965397] pnp 00:00: [mem 0xf0000000-0xfec00000 window]
[ 1.965400] pnp 00:00: [mem 0x80000000-0xdfffffff window]
[ 1.965403] pnp 00:00: [mem 0xf0000000-0xefffffff window disabled]
[ 1.965406] pnp 00:00: [mem 0xff980800-0xff980bff window]
[ 1.965409] pnp 00:00: [mem 0xff97c000-0xff97ffff window]
[ 1.965412] pnp 00:00: [mem 0xfed20000-0xfed9ffff window]
[ 1.965460] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 1.969462] pnp 00:01: [io 0x0060]
[ 1.969465] pnp 00:01: [io 0x0064]
[ 1.969467] pnp 00:01: [io 0x0062-0x0063]
[ 1.969470] pnp 00:01: [io 0x0065-0x006f]
[ 1.969473] pnp 00:01: [io 0x00e0-0x00ef]
[ 1.969475] pnp 00:01: [io 0x0800-0x085f]
[ 1.969478] pnp 00:01: [io 0x0c00-0x0c7f]
[ 1.969480] pnp 00:01: [io 0x0860-0x08ff]
[ 1.969541] system 00:01: [io 0x0800-0x085f] has been reserved
[ 1.969545] system 00:01: [io 0x0c00-0x0c7f] has been reserved
[ 1.969549] system 00:01: [io 0x0860-0x08ff] has been reserved
[ 1.969553] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 1.969844] pnp 00:02: [io 0x0080-0x009f]
[ 1.969847] pnp 00:02: [io 0x0000-0x001f]
[ 1.969849] pnp 00:02: [io 0x00c0-0x00df]
[ 1.969853] pnp 00:02: [dma 4]
[ 1.969887] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 1.970113] pnp 00:03: [io 0x00f0-0x00ff]
[ 1.970121] pnp 00:03: [irq 13]
[ 1.970158] pnp 00:03: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 1.970372] pnp 00:04: [io 0x0061]
[ 1.970408] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
[ 1.970631] pnp 00:05: [io 0x0070-0x007f]
[ 1.970638] pnp 00:05: [irq 8]
[ 1.970674] pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 1.979183] pnp 00:06: [io 0x03f0-0x03f5]
[ 1.979187] pnp 00:06: [io 0x03f7]
[ 1.979192] pnp 00:06: [irq 6]
[ 1.979195] pnp 00:06: [dma 2]
[ 1.979717] pnp 00:06: Plug and Play ACPI device, IDs PNP0700 (active)
[ 1.992767] pnp 00:07: [io 0x0378-0x037f]
[ 1.992770] pnp 00:07: [io 0x0778-0x077f]
[ 1.992776] pnp 00:07: [irq 7]
[ 1.992779] pnp 00:07: [dma 0 disabled]
[ 1.994011] pnp 00:07: Plug and Play ACPI device, IDs PNP0401 (active)
[ 2.000775] pnp 00:08: [io 0x03f8-0x03ff]
[ 2.000781] pnp 00:08: [irq 4]
[ 2.001207] pnp 00:08: Plug and Play ACPI device, IDs PNP0501 (active)
[ 2.023081] pnp 00:09: [mem 0x00000000-0x0009ffff]
[ 2.023085] pnp 00:09: [mem 0x00100000-0x00ffffff]
[ 2.023088] pnp 00:09: [mem 0x01000000-0x7f5ffbff]
[ 2.023090] pnp 00:09: [mem 0x000f0000-0x000fffff]
[ 2.023093] pnp 00:09: [mem 0x000c0000-0x000cffff]
[ 2.023096] pnp 00:09: [mem 0xfec00000-0xfecfffff]
[ 2.023099] pnp 00:09: [mem 0xfee00000-0xfeefffff]
[ 2.023102] pnp 00:09: [mem 0xffb00000-0xffbfffff]
[ 2.023104] pnp 00:09: [mem 0xffc00000-0xffffffff]
[ 2.023176] system 00:09: [mem 0x00000000-0x0009ffff] could not be reserved
[ 2.023180] system 00:09: [mem 0x00100000-0x00ffffff] could not be reserved
[ 2.023184] system 00:09: [mem 0x01000000-0x7f5ffbff] could not be reserved
[ 2.023188] system 00:09: [mem 0x000f0000-0x000fffff] could not be reserved
[ 2.023192] system 00:09: [mem 0x000c0000-0x000cffff] could not be reserved
[ 2.023195] system 00:09: [mem 0xfec00000-0xfecfffff] could not be reserved
[ 2.023199] system 00:09: [mem 0xfee00000-0xfeefffff] has been reserved
[ 2.023202] system 00:09: [mem 0xffb00000-0xffbfffff] has been reserved
[ 2.023206] system 00:09: [mem 0xffc00000-0xffffffff] has been reserved
[ 2.023210] system 00:09: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 2.026395] pnp 00:0a: [mem 0xe0000000-0xefffffff]
[ 2.026398] pnp 00:0a: [mem 0xfeda0000-0xfedacfff]
[ 2.026401] pnp 00:0a: [io 0x0100-0x01fe]
[ 2.026404] pnp 00:0a: [io 0x0200-0x0277]
[ 2.026406] pnp 00:0a: [io 0x0280-0x02e7]
[ 2.026409] pnp 00:0a: [io 0x02f0-0x02f7]
[ 2.026411] pnp 00:0a: [io 0x0300-0x0377]
[ 2.026414] pnp 00:0a: [io 0x0380-0x03bb]
[ 2.026417] pnp 00:0a: [io 0x03c0-0x03e7]
[ 2.026419] pnp 00:0a: [io 0x03f6-0x03f7]
[ 2.026422] pnp 00:0a: [io 0x0400-0x04cf]
[ 2.026424] pnp 00:0a: [io 0x04d2-0x057f]
[ 2.026427] pnp 00:0a: [io 0x0580-0x0677]
[ 2.026431] pnp 00:0a: [io 0x0680-0x0777]
[ 2.026433] pnp 00:0a: [io 0x0780-0x07bb]
[ 2.026436] pnp 00:0a: [io 0x07c0-0x07ff]
[ 2.026438] pnp 00:0a: [io 0x08e0-0x08ff]
[ 2.026441] pnp 00:0a: [io 0x0900-0x09fe]
[ 2.026443] pnp 00:0a: [io 0x0a00-0x0afe]
[ 2.026446] pnp 00:0a: [io 0x0b00-0x0bfe]
[ 2.026449] pnp 00:0a: [io 0x0c80-0x0caf]
[ 2.026451] pnp 00:0a: [io 0x0cc0-0x0cf7]
[ 2.026454] pnp 00:0a: [io 0x0d00-0x0dfe]
[ 2.026456] pnp 00:0a: [io 0x0e00-0x0efe]
[ 2.026459] pnp 00:0a: [io 0x0f00-0x0ffe]
[ 2.026461] pnp 00:0a: [io 0x2000-0x20fe]
[ 2.026464] pnp 00:0a: [io 0x2100-0x21fe]
[ 2.026466] pnp 00:0a: [io 0x2200-0x22fe]
[ 2.026469] pnp 00:0a: [io 0x2300-0x23fe]
[ 2.026471] pnp 00:0a: [io 0x2400-0x24fe]
[ 2.026474] pnp 00:0a: [io 0x2500-0x25fe]
[ 2.026476] pnp 00:0a: [io 0x2600-0x26fe]
[ 2.026479] pnp 00:0a: [io 0x2700-0x27fe]
[ 2.026482] pnp 00:0a: [io 0x2800-0x28fe]
[ 2.026484] pnp 00:0a: [io 0x2900-0x29fe]
[ 2.026487] pnp 00:0a: [io 0x2a00-0x2afe]
[ 2.026489] pnp 00:0a: [io 0x2b00-0x2bfe]
[ 2.026492] pnp 00:0a: [io 0x2c00-0x2cfe]
[ 2.026494] pnp 00:0a: [io 0x2d00-0x2dfe]
[ 2.026497] pnp 00:0a: [io 0x2e00-0x2efe]
[ 2.026499] pnp 00:0a: [io 0x2f00-0x2ffe]
[ 2.026502] pnp 00:0a: [io 0x5000-0x50fe]
[ 2.026504] pnp 00:0a: [io 0x5100-0x51fe]
[ 2.026507] pnp 00:0a: [io 0x5200-0x52fe]
[ 2.026510] pnp 00:0a: [io 0x5300-0x53fe]
[ 2.026512] pnp 00:0a: [io 0x5400-0x54fe]
[ 2.026515] pnp 00:0a: [io 0x5500-0x55fe]
[ 2.026517] pnp 00:0a: [io 0x5600-0x56fe]
[ 2.026520] pnp 00:0a: [io 0x5700-0x57fe]
[ 2.026522] pnp 00:0a: [io 0x5800-0x58fe]
[ 2.026525] pnp 00:0a: [io 0x5900-0x59fe]
[ 2.026527] pnp 00:0a: [io 0x5a00-0x5afe]
[ 2.026530] pnp 00:0a: [io 0x5b00-0x5bfe]
[ 2.026532] pnp 00:0a: [io 0x5c00-0x5cfe]
[ 2.026535] pnp 00:0a: [io 0x5d00-0x5dfe]
[ 2.026537] pnp 00:0a: [io 0x5e00-0x5efe]
[ 2.026540] pnp 00:0a: [io 0x5f00-0x5ffe]
[ 2.026543] pnp 00:0a: [io 0x6000-0x60fe]
[ 2.026545] pnp 00:0a: [io 0x6100-0x61fe]
[ 2.026548] pnp 00:0a: [io 0x6200-0x62fe]
[ 2.026550] pnp 00:0a: [io 0x6300-0x63fe]
[ 2.026553] pnp 00:0a: [io 0x6400-0x64fe]
[ 2.026555] pnp 00:0a: [io 0x6500-0x65fe]
[ 2.026558] pnp 00:0a: [io 0x6600-0x66fe]
[ 2.026560] pnp 00:0a: [io 0x6700-0x67fe]
[ 2.026563] pnp 00:0a: [io 0x6800-0x68fe]
[ 2.026566] pnp 00:0a: [io 0x6900-0x69fe]
[ 2.026568] pnp 00:0a: [io 0x6a00-0x6afe]
[ 2.026571] pnp 00:0a: [io 0x6b00-0x6bfe]
[ 2.026573] pnp 00:0a: [io 0x6c00-0x6cfe]
[ 2.026576] pnp 00:0a: [io 0x6d00-0x6dfe]
[ 2.026578] pnp 00:0a: [io 0x6e00-0x6efe]
[ 2.026582] pnp 00:0a: [io 0x6f00-0x6ffe]
[ 2.026585] pnp 00:0a: [io 0xa000-0xa0fe]
[ 2.026587] pnp 00:0a: [io 0xa100-0xa1fe]
[ 2.026590] pnp 00:0a: [io 0xa200-0xa2fe]
[ 2.026592] pnp 00:0a: [io 0xa300-0xa3fe]
[ 2.026595] pnp 00:0a: [io 0xa400-0xa4fe]
[ 2.026597] pnp 00:0a: [io 0xa500-0xa5fe]
[ 2.026600] pnp 00:0a: [io 0xa600-0xa6fe]
[ 2.026602] pnp 00:0a: [io 0xa700-0xa7fe]
[ 2.026605] pnp 00:0a: [io 0xa800-0xa8fe]
[ 2.026607] pnp 00:0a: [io 0xa900-0xa9fe]
[ 2.026610] pnp 00:0a: [io 0xaa00-0xaafe]
[ 2.026612] pnp 00:0a: [io 0xab00-0xabfe]
[ 2.026615] pnp 00:0a: [io 0xac00-0xacfe]
[ 2.026618] pnp 00:0a: [io 0xad00-0xadfe]
[ 2.026620] pnp 00:0a: [io 0xae00-0xaefe]
[ 2.026623] pnp 00:0a: [io 0xaf00-0xaffe]
[ 2.026862] system 00:0a: [io 0x0100-0x01fe] has been reserved
[ 2.026865] system 00:0a: [io 0x0200-0x0277] has been reserved
[ 2.026869] system 00:0a: [io 0x0280-0x02e7] has been reserved
[ 2.026872] system 00:0a: [io 0x02f0-0x02f7] has been reserved
[ 2.026875] system 00:0a: [io 0x0300-0x0377] has been reserved
[ 2.026879] system 00:0a: [io 0x0380-0x03bb] has been reserved
[ 2.026882] system 00:0a: [io 0x03c0-0x03e7] could not be reserved
[ 2.026886] system 00:0a: [io 0x03f6-0x03f7] has been reserved
[ 2.026889] system 00:0a: [io 0x0400-0x04cf] has been reserved
[ 2.026892] system 00:0a: [io 0x04d2-0x057f] has been reserved
[ 2.026896] system 00:0a: [io 0x0580-0x0677] has been reserved
[ 2.026899] system 00:0a: [io 0x0680-0x0777] has been reserved
[ 2.026902] system 00:0a: [io 0x0780-0x07bb] has been reserved
[ 2.026906] system 00:0a: [io 0x07c0-0x07ff] has been reserved
[ 2.026909] system 00:0a: [io 0x08e0-0x08ff] has been reserved
[ 2.026912] system 00:0a: [io 0x0900-0x09fe] has been reserved
[ 2.026916] system 00:0a: [io 0x0a00-0x0afe] has been reserved
[ 2.026919] system 00:0a: [io 0x0b00-0x0bfe] has been reserved
[ 2.026922] system 00:0a: [io 0x0c80-0x0caf] has been reserved
[ 2.026926] system 00:0a: [io 0x0cc0-0x0cf7] has been reserved
[ 2.026929] system 00:0a: [io 0x0d00-0x0dfe] has been reserved
[ 2.026932] system 00:0a: [io 0x0e00-0x0efe] has been reserved
[ 2.026936] system 00:0a: [io 0x0f00-0x0ffe] has been reserved
[ 2.026939] system 00:0a: [io 0x2000-0x20fe] has been reserved
[ 2.026942] system 00:0a: [io 0x2100-0x21fe] has been reserved
[ 2.026946] system 00:0a: [io 0x2200-0x22fe] has been reserved
[ 2.026951] system 00:0a: [io 0x2300-0x23fe] has been reserved
[ 2.026954] system 00:0a: [io 0x2400-0x24fe] has been reserved
[ 2.026958] system 00:0a: [io 0x2500-0x25fe] has been reserved
[ 2.026961] system 00:0a: [io 0x2600-0x26fe] has been reserved
[ 2.026964] system 00:0a: [io 0x2700-0x27fe] has been reserved
[ 2.026968] system 00:0a: [io 0x2800-0x28fe] has been reserved
[ 2.026971] system 00:0a: [io 0x2900-0x29fe] has been reserved
[ 2.026975] system 00:0a: [io 0x2a00-0x2afe] has been reserved
[ 2.026978] system 00:0a: [io 0x2b00-0x2bfe] has been reserved
[ 2.026982] system 00:0a: [io 0x2c00-0x2cfe] has been reserved
[ 2.026985] system 00:0a: [io 0x2d00-0x2dfe] has been reserved
[ 2.026988] system 00:0a: [io 0x2e00-0x2efe] has been reserved
[ 2.026992] system 00:0a: [io 0x2f00-0x2ffe] has been reserved
[ 2.026995] system 00:0a: [io 0x5000-0x50fe] has been reserved
[ 2.026999] system 00:0a: [io 0x5100-0x51fe] has been reserved
[ 2.027002] system 00:0a: [io 0x5200-0x52fe] has been reserved
[ 2.027006] system 00:0a: [io 0x5300-0x53fe] has been reserved
[ 2.027009] system 00:0a: [io 0x5400-0x54fe] has been reserved
[ 2.027013] system 00:0a: [io 0x5500-0x55fe] has been reserved
[ 2.027016] system 00:0a: [io 0x5600-0x56fe] has been reserved
[ 2.027020] system 00:0a: [io 0x5700-0x57fe] has been reserved
[ 2.027023] system 00:0a: [io 0x5800-0x58fe] has been reserved
[ 2.027027] system 00:0a: [io 0x5900-0x59fe] has been reserved
[ 2.027030] system 00:0a: [io 0x5a00-0x5afe] has been reserved
[ 2.027034] system 00:0a: [io 0x5b00-0x5bfe] has been reserved
[ 2.027037] system 00:0a: [io 0x5c00-0x5cfe] has been reserved
[ 2.027041] system 00:0a: [io 0x5d00-0x5dfe] has been reserved
[ 2.027044] system 00:0a: [io 0x5e00-0x5efe] has been reserved
[ 2.027048] system 00:0a: [io 0x5f00-0x5ffe] has been reserved
[ 2.027051] system 00:0a: [io 0x6000-0x60fe] has been reserved
[ 2.027055] system 00:0a: [io 0x6100-0x61fe] has been reserved
[ 2.027059] system 00:0a: [io 0x6200-0x62fe] has been reserved
[ 2.027062] system 00:0a: [io 0x6300-0x63fe] has been reserved
[ 2.027066] system 00:0a: [io 0x6400-0x64fe] has been reserved
[ 2.027070] system 00:0a: [io 0x6500-0x65fe] has been reserved
[ 2.027073] system 00:0a: [io 0x6600-0x66fe] has been reserved
[ 2.027077] system 00:0a: [io 0x6700-0x67fe] has been reserved
[ 2.027080] system 00:0a: [io 0x6800-0x68fe] has been reserved
[ 2.027084] system 00:0a: [io 0x6900-0x69fe] has been reserved
[ 2.027087] system 00:0a: [io 0x6a00-0x6afe] has been reserved
[ 2.027091] system 00:0a: [io 0x6b00-0x6bfe] has been reserved
[ 2.027094] system 00:0a: [io 0x6c00-0x6cfe] has been reserved
[ 2.027098] system 00:0a: [io 0x6d00-0x6dfe] has been reserved
[ 2.027101] system 00:0a: [io 0x6e00-0x6efe] has been reserved
[ 2.027105] system 00:0a: [io 0x6f00-0x6ffe] has been reserved
[ 2.027108] system 00:0a: [io 0xa000-0xa0fe] has been reserved
[ 2.027112] system 00:0a: [io 0xa100-0xa1fe] has been reserved
[ 2.027116] system 00:0a: [io 0xa200-0xa2fe] has been reserved
[ 2.027119] system 00:0a: [io 0xa300-0xa3fe] has been reserved
[ 2.027123] system 00:0a: [io 0xa400-0xa4fe] has been reserved
[ 2.027126] system 00:0a: [io 0xa500-0xa5fe] has been reserved
[ 2.027130] system 00:0a: [io 0xa600-0xa6fe] has been reserved
[ 2.027134] system 00:0a: [io 0xa700-0xa7fe] has been reserved
[ 2.027137] system 00:0a: [io 0xa800-0xa8fe] has been reserved
[ 2.027141] system 00:0a: [io 0xa900-0xa9fe] has been reserved
[ 2.027144] system 00:0a: [io 0xaa00-0xaafe] has been reserved
[ 2.027148] system 00:0a: [io 0xab00-0xabfe] has been reserved
[ 2.027153] system 00:0a: [io 0xac00-0xacfe] has been reserved
[ 2.027157] system 00:0a: [io 0xad00-0xadfe] has been reserved
[ 2.027161] system 00:0a: [io 0xae00-0xaefe] has been reserved
[ 2.027164] system 00:0a: [io 0xaf00-0xaffe] has been reserved
[ 2.027168] system 00:0a: [mem 0xe0000000-0xefffffff] has been reserved
[ 2.027172] system 00:0a: [mem 0xfeda0000-0xfedacfff] has been reserved
[ 2.027176] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 2.027403] pnp 00:0b: [mem 0xfed00000-0xfed003ff]
[ 2.027449] pnp 00:0b: Plug and Play ACPI device, IDs PNP0103 (active)
[ 2.027457] pnp: PnP ACPI: found 12 devices
[ 2.027459] ACPI: ACPI bus type pnp unregistered
[ 2.027463] PnPBIOS: Disabled by ACPI PNP
[ 2.064895] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 02-02] add_size 1000
[ 2.064900] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02-02] add_size 200000
[ 2.064910] pci 0000:00:1c.4: bridge window [io 0x1000-0x0fff] to [bus 03-03] add_size 1000
[ 2.064914] pci 0000:00:1c.4: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03-03] add_size 200000
[ 2.064928] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 2.064932] pci 0000:00:1c.4: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 2.064936] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 2.064939] pci 0000:00:1c.4: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 2.064944] pci 0000:00:1c.0: BAR 15: assigned [mem 0x80000000-0x801fffff 64bit pref]
[ 2.064948] pci 0000:00:1c.4: BAR 15: assigned [mem 0x80200000-0x803fffff 64bit pref]
[ 2.064952] pci 0000:00:1c.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.064956] pci 0000:00:1c.4: BAR 13: assigned [io 0x3000-0x3fff]
[ 2.064960] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 2.064965] pci 0000:00:01.0: bridge window [mem 0xfe800000-0xfe8fffff]
[ 2.064972] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 2.064976] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff]
[ 2.064981] pci 0000:00:1c.0: bridge window [mem 0xfe700000-0xfe7fffff]
[ 2.064986] pci 0000:00:1c.0: bridge window [mem 0x80000000-0x801fffff 64bit pref]
[ 2.064993] pci 0000:00:1c.4: PCI bridge to [bus 03-03]
[ 2.064996] pci 0000:00:1c.4: bridge window [io 0x3000-0x3fff]
[ 2.065002] pci 0000:00:1c.4: bridge window [mem 0xfe600000-0xfe6fffff]
[ 2.065007] pci 0000:00:1c.4: bridge window [mem 0x80200000-0x803fffff 64bit pref]
[ 2.065014] pci 0000:00:1e.0: PCI bridge to [bus 04-04]
[ 2.065019] pci 0000:00:1e.0: bridge window [mem 0xfe500000-0xfe5fffff]
[ 2.065057] pci 0000:00:1e.0: setting latency timer to 64
[ 2.065061] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 2.065064] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[ 2.065067] pci_bus 0000:01: resource 1 [mem 0xfe800000-0xfe8fffff]
[ 2.065070] pci_bus 0000:02: resource 0 [io 0x1000-0x1fff]
[ 2.065073] pci_bus 0000:02: resource 1 [mem 0xfe700000-0xfe7fffff]
[ 2.065076] pci_bus 0000:02: resource 2 [mem 0x80000000-0x801fffff 64bit pref]
[ 2.065079] pci_bus 0000:03: resource 0 [io 0x3000-0x3fff]
[ 2.065082] pci_bus 0000:03: resource 1 [mem 0xfe600000-0xfe6fffff]
[ 2.065085] pci_bus 0000:03: resource 2 [mem 0x80200000-0x803fffff 64bit pref]
[ 2.065088] pci_bus 0000:04: resource 1 [mem 0xfe500000-0xfe5fffff]
[ 2.065091] pci_bus 0000:04: resource 4 [io 0x0000-0xffff]
[ 2.065094] pci_bus 0000:04: resource 5 [mem 0x00000000-0xffffffff]
[ 2.065179] NET: Registered protocol family 2
[ 2.065263] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 2.065514] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 2.065860] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 2.066036] TCP: Hash tables configured (established 131072 bind 65536)
[ 2.066038] TCP: reno registered
[ 2.066042] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 2.066050] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 2.066164] NET: Registered protocol family 1
[ 2.066186] pci 0000:00:02.0: Boot video device
[ 2.066401] PCI: CLS 64 bytes, default 64
[ 2.066460] Unpacking initramfs...
[ 2.376102] Freeing initrd memory: 13720k freed
[ 2.383647] Simple Boot Flag at 0x7a set to 0x1
[ 2.384281] audit: initializing netlink socket (disabled)
[ 2.384299] type=2000 audit(1539042464.380:1): initialized
[ 2.397019] highmem bounce pool size: 64 pages
[ 2.397026] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 2.397246] VFS: Disk quotas dquot_6.5.2
[ 2.397283] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 2.397374] msgmni has been set to 1721
[ 2.397574] alg: No test for stdrng (krng)
[ 2.397609] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 2.397614] io scheduler noop registered
[ 2.397616] io scheduler deadline registered
[ 2.397637] io scheduler cfq registered (default)
[ 2.397923] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 2.397950] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 2.397953] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 2.398656] GHES: HEST is not enabled!
[ 2.398670] isapnp: Scanning for PnP cards...
[ 2.751699] isapnp: No Plug & Play device found
[ 2.751760] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 2.772131] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 2.792846] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 2.793271] Linux agpgart interface v0.103
[ 2.793407] agpgart-intel 0000:00:00.0: Intel 965Q Chipset
[ 2.793482] agpgart-intel 0000:00:00.0: detected gtt size: 524288K total, 262144K mappable
[ 2.793969] agpgart-intel 0000:00:00.0: detected 8192K stolen memory
[ 2.794090] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xd0000000
[ 2.794270] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 2.797173] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 2.797211] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 2.797337] mousedev: PS/2 mouse device common for all mice
[ 2.797400] rtc_cmos 00:05: RTC can wake from S4
[ 2.797533] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 2.797558] rtc0: alarms up to one day, 242 bytes nvram, hpet irqs
[ 2.797718] TCP: cubic registered
[ 2.797779] NET: Registered protocol family 10
[ 2.798063] Mobile IPv6
[ 2.798067] NET: Registered protocol family 17
[ 2.798072] Registering the dns_resolver key type
[ 2.798138] Using IPI No-Shortcut mode
[ 2.798262] PM: Hibernation image not present or could not be loaded.
[ 2.798275] registered taskstats version 1
[ 2.798679] rtc_cmos 00:05: setting system clock to 2018-10-08 23:47:45 UTC (1539042465)
[ 2.798783] Freeing unused kernel memory: 416k freed
[ 2.799001] Write protecting the kernel text: 3496k
[ 2.799028] Write protecting the kernel read-only data: 984k
[ 2.811888] udevd[49]: starting version 175
[ 2.832846] usbcore: registered new interface driver usbfs
[ 2.832877] usbcore: registered new interface driver hub
[ 2.837073] usbcore: registered new device driver usb
[ 2.837598] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.837669] ehci_hcd 0000:00:1a.7: setting latency timer to 64
[ 2.837674] ehci_hcd 0000:00:1a.7: EHCI Host Controller
[ 2.837707] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1
[ 2.837740] ehci_hcd 0000:00:1a.7: debug port 1
[ 2.846565] SCSI subsystem initialized
[ 2.849421] ehci_hcd 0000:00:1a.7: cache line size of 64 is not supported
[ 2.849449] ehci_hcd 0000:00:1a.7: irq 22, io mem 0xfe9fbc00
[ 2.849497] libata version 3.00 loaded.
[ 2.854227] microcode: CPU0 sig=0x6f2, pf=0x1, revision=0x56
[ 2.857089] uhci_hcd: USB Universal Host Controller Interface driver
[ 2.860030] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 2.860084] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.860088] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.860092] usb usb1: Product: EHCI Host Controller
[ 2.860094] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 2.860097] usb usb1: SerialNumber: 0000:00:1a.7
[ 2.860254] hub 1-0:1.0: USB hub found
[ 2.860261] hub 1-0:1.0: 4 ports detected
[ 2.860411] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 2.860415] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 2.860428] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 2
[ 2.860463] ehci_hcd 0000:00:1d.7: debug port 1
[ 2.864546] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[ 2.864572] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xff980800
[ 2.869865] tg3.c:v3.123 (March 21, 2012)
[ 2.876069] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 2.876103] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.876107] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.876110] usb usb2: Product: EHCI Host Controller
[ 2.876113] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 2.876115] usb usb2: SerialNumber: 0000:00:1d.7
[ 2.876265] hub 2-0:1.0: USB hub found
[ 2.876272] hub 2-0:1.0: 6 ports detected
[ 2.876740] ata_piix 0000:00:1f.2: version 2.13
[ 2.876770] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 2.886043] Floppy drive(s): fd0 is 1.44M
[ 2.893095] tg3 0000:03:00.0: eth0: Tigon3 [partno(BCM95754) rev b002] (PCI Express) MAC address 00:1a:a0:ae:38:fc
[ 2.893100] tg3 0000:03:00.0: eth0: attached PHY is 5787 (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[0])
[ 2.893105] tg3 0000:03:00.0: eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[ 2.893108] tg3 0000:03:00.0: eth0: dma_rwctrl[76180000] dma_mask[64-bit]
[ 2.902189] FDC 0 is a post-1991 82077
[ 2.908953] microcode: CPU0 updated to revision 0x5d, date = 2010-10-02
[ 2.908969] microcode: CPU1 sig=0x6f2, pf=0x1, revision=0x56
[ 2.911669] microcode: CPU1 updated to revision 0x5d, date = 2010-10-02
[ 2.911722] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 3.032078] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 3.032552] scsi0 : ata_piix
[ 3.032679] scsi1 : ata_piix
[ 3.037584] ata1: SATA max UDMA/133 cmd 0xfe00 ctl 0xfe10 bmdma 0xfec0 irq 20
[ 3.037590] ata2: SATA max UDMA/133 cmd 0xfe20 ctl 0xfe30 bmdma 0xfec8 irq 20
[ 3.037656] uhci_hcd 0000:00:1a.0: setting latency timer to 64
[ 3.037661] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 3.037675] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[ 3.037713] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000ff20
[ 3.037757] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.037761] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.037764] usb usb3: Product: UHCI Host Controller
[ 3.037766] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 3.037769] usb usb3: SerialNumber: 0000:00:1a.0
[ 3.037912] hub 3-0:1.0: USB hub found
[ 3.037918] hub 3-0:1.0: 2 ports detected
[ 3.038022] uhci_hcd 0000:00:1a.1: setting latency timer to 64
[ 3.038026] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 3.038036] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
[ 3.038074] uhci_hcd 0000:00:1a.1: irq 17, io base 0x0000ff00
[ 3.038116] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.038119] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.038122] usb usb4: Product: UHCI Host Controller
[ 3.038125] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 3.038128] usb usb4: SerialNumber: 0000:00:1a.1
[ 3.038503] hub 4-0:1.0: USB hub found
[ 3.038509] hub 4-0:1.0: 2 ports detected
[ 3.038612] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 3.038617] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 3.038626] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 5
[ 3.038652] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000ff80
[ 3.038692] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.038695] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.038698] usb usb5: Product: UHCI Host Controller
[ 3.038701] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 3.038703] usb usb5: SerialNumber: 0000:00:1d.0
[ 3.038914] hub 5-0:1.0: USB hub found
[ 3.038920] hub 5-0:1.0: 2 ports detected
[ 3.039022] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 3.039026] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 3.039035] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 6
[ 3.039060] uhci_hcd 0000:00:1d.1: irq 17, io base 0x0000ff60
[ 3.039103] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.039106] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.039109] usb usb6: Product: UHCI Host Controller
[ 3.039112] usb usb6: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 3.039114] usb usb6: SerialNumber: 0000:00:1d.1
[ 3.040046] hub 6-0:1.0: USB hub found
[ 3.040054] hub 6-0:1.0: 2 ports detected
[ 3.040161] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 3.040165] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 3.040175] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 7
[ 3.040218] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000ff40
[ 3.040262] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.040265] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.040268] usb usb7: Product: UHCI Host Controller
[ 3.040271] usb usb7: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 3.040274] usb usb7: SerialNumber: 0000:00:1d.2
[ 3.040461] hub 7-0:1.0: USB hub found
[ 3.040467] hub 7-0:1.0: 2 ports detected
[ 3.041723] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
[ 3.196085] ata_piix 0000:00:1f.5: setting latency timer to 64
[ 3.196462] scsi2 : ata_piix
[ 3.196560] scsi3 : ata_piix
[ 3.196624] ata3: SATA max UDMA/133 cmd 0xfe40 ctl 0xfe50 bmdma 0xfed0 irq 20
[ 3.196629] ata4: SATA max UDMA/133 cmd 0xfe60 ctl 0xfe70 bmdma 0xfed8 irq 20
[ 3.348039] usb 3-1: new low-speed USB device number 2 using uhci_hcd
[ 3.380059] Refined TSC clocksource calibration: 2127.999 MHz.
[ 3.380067] Switching to clocksource tsc
[ 3.516104] ata3: SATA link down (SStatus 0 SControl 300)
[ 3.516173] ata4: SATA link down (SStatus 0 SControl 300)
[ 3.520759] usb 3-1: New USB device found, idVendor=0e6a, idProduct=6001
[ 3.520763] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.520767] usb 3-1: Product: HID Keyboard Device
[ 3.574317] input: HID Keyboard Device as /devices/pci0000:00/0000:00:1a.0/usb3/3-1/3-1:1.0/input/input0
[ 3.574386] generic-usb 0003:0E6A:6001.0001: input,hidraw0: USB HID v1.10 Keyboard [HID Keyboard Device] on usb-0000:00:1a.0-1/input0
[ 3.596889] input: HID Keyboard Device as /devices/pci0000:00/0000:00:1a.0/usb3/3-1/3-1:1.1/input/input1
[ 3.596962] generic-usb 0003:0E6A:6001.0002: input,hidraw1: USB HID v1.10 Device [HID Keyboard Device] on usb-0000:00:1a.0-1/input1
[ 3.597000] usbcore: registered new interface driver usbhid
[ 3.597002] usbhid: USB HID core driver
[ 3.664039] usb 3-2: new low-speed USB device number 3 using uhci_hcd
[ 3.832105] ata1.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 3.832118] ata1.01: SATA link down (SStatus 4 SControl 300)
[ 3.832326] ata2.00: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 3.832339] ata2.01: SATA link down (SStatus 4 SControl 300)
[ 3.832350] ata2.01: link offline, clearing class 3 to NONE
[ 3.839757] usb 3-2: New USB device found, idVendor=046d, idProduct=c016
[ 3.839762] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.839766] usb 3-2: Product: Optical USB Mouse
[ 3.839769] usb 3-2: Manufacturer: Logitech
[ 3.840154] ata2.00: ATAPI: HL-DT-ST DVDRAM GH15F, EG00, max UDMA/100
[ 3.841064] ata1.00: ATA-8: WDC WD2500BPVT-00JJ5T0, 01.01A01, max UDMA/133
[ 3.841070] ata1.00: 488397168 sectors, multi 8: LBA48 NCQ (depth 0/32)
[ 3.853099] ata1.00: configured for UDMA/133
[ 3.853268] scsi 0:0:0:0: Direct-Access ATA WDC WD2500BPVT-0 01.0 PQ: 0 ANSI: 5
[ 3.856177] ata2.00: configured for UDMA/100
[ 3.856294] input: Logitech Optical USB Mouse as /devices/pci0000:00/0000:00:1a.0/usb3/3-2/3-2:1.0/input/input2
[ 3.856388] generic-usb 0003:046D:C016.0003: input,hidraw2: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-0000:00:1a.0-2/input0
[ 3.973820] scsi 1:0:0:0: CD-ROM HL-DT-ST DVDRAM GH15F EG00 PQ: 0 ANSI: 5
[ 3.984145] sd 0:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/232 GiB)
[ 3.984150] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 3.984220] sd 0:0:0:0: [sda] Write Protect is off
[ 3.984223] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 3.984254] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 4.047404] sda: sda1 sda2 < sda5 >
[ 4.047860] sd 0:0:0:0: [sda] Attached SCSI disk
[ 4.049718] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 4.049770] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 4.092423] sr0: scsi3-mmc drive: 40x/40x writer dvd-ram cd/rw xa/form2 cdda tray
[ 4.092429] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 4.092693] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 9.623121] PM: Starting manual resume from disk
[ 9.623125] PM: Hibernation image partition 8:5 present
[ 9.623128] PM: Looking for hibernation image.
[ 9.623508] PM: Image not found (code -22)
[ 9.623513] PM: Hibernation image not present or could not be loaded.
[ 9.720337] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 11.950385] udevd[345]: starting version 175
[ 12.364900] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[ 12.364909] ACPI: Power Button [VBTN]
[ 12.365041] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[ 12.365046] ACPI: Power Button [PWRF]
[ 12.886522] coretemp coretemp.0: Using relative temperature scale!
[ 12.886535] coretemp coretemp.0: Using relative temperature scale!
[ 12.893560] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 12.953500] iTCO_vendor_support: vendor-support=0
[ 13.150769] [drm] Initialized drm 1.1.0 20060810
[ 13.195046] i915 0000:00:02.0: setting latency timer to 64
[ 13.209709] mtrr: type mismatch for d0000000,10000000 old: write-back new: write-combining
[ 13.209712] [drm] MTRR allocation failed. Graphics performance may suffer.
[ 13.209975] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 13.209978] [drm] Driver supports precise vblank timestamp query.
[ 13.210023] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 13.228687] [drm] initialized overlay support
[ 13.275790] fbcon: inteldrmfb (fb0) is primary device
[ 13.281325] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 13.281406] parport_pc 00:07: reported by Plug and Play ACPI
[ 13.281437] iTCO_wdt: unable to reset NO_REBOOT flag, device disabled by hardware/BIOS
[ 13.281467] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 13.323911] Console: switching to colour frame buffer device 240x67
[ 13.331274] fb0: inteldrmfb frame buffer device
[ 13.331277] drm: registered panic notifier
[ 13.331324] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 13.435717] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input5
[ 15.663864] Adding 4170748k swap on /dev/sda5. Priority:-1 extents:1 across:4170748k
[ 15.679206] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 15.918403] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 16.024934] loop: module loaded
[ 17.333553] RPC: Registered named UNIX socket transport module.
[ 17.333557] RPC: Registered udp transport module.
[ 17.333559] RPC: Registered tcp transport module.
[ 17.333561] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 17.406334] FS-Cache: Loaded
[ 17.437446] NFS: Registering the id_resolver key type
[ 17.437471] FS-Cache: Netfs 'nfs' registered for caching
[ 17.452892] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 19.681877] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input6
[ 20.480523] lp0: using parport0 (interrupt-driven).
[ 20.679971] ppdev: user-space parallel port driver
[ 20.934385] Bluetooth: Core ver 2.16
[ 20.934407] NET: Registered protocol family 31
[ 20.934409] Bluetooth: HCI device and connection manager initialized
[ 20.934413] Bluetooth: HCI socket layer initialized
[ 20.934415] Bluetooth: L2CAP socket layer initialized
[ 20.934421] Bluetooth: SCO socket layer initialized
[ 21.048660] Bluetooth: RFCOMM TTY layer initialized
[ 21.048666] Bluetooth: RFCOMM socket layer initialized
[ 21.048668] Bluetooth: RFCOMM ver 1.11
[ 21.346526] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 21.346530] Bluetooth: BNEP filters: protocol multicast
[ 24.183660] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 27.824848] tg3 0000:03:00.0: eth0: Link is up at 1000 Mbps, full duplex
[ 27.824853] tg3 0000:03:00.0: eth0: Flow control is on for TX and on for RX
[ 27.825034] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 38.688278] eth0: no IPv6 routers present
[ 102.699343] I-pipe: head domain RTAI registered.
[ 102.699349] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 102.699408] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 102.699412] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2127938000, CPU_FREQ 2127938000
[ 102.699416] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 102.699419] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 8837750
[ 102.752802] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 102.752843] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 102.752848] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[ 102.752852] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2127938000 hz.
[ 102.752854] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 102.760811] RTAI[math]: loaded.
[ 103.039324] hm2: loading Mesa HostMot2 driver version 0.15
[ 103.126744] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 103.126788] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 103.126899] hm2/hm2_5i25.0: config.num_encoders=6, but only 2 are available, not loading driver
[ 103.126904] hm2/hm2_5i25.0: failed to parse Module Descriptor 2
[ 103.126910] hm2_5i25.0: board fails HM2 registration
[ 103.126926] hm2_pci: probe of 0000:04:00.0 failed with error -22
[ 103.494850] hm2: unloading
[ 105.647976] RTAI[math]: unloaded.
[ 105.649980] SCHED releases registered named ALIEN PEDV$D
[ 105.656036] RTAI[malloc]: unloaded.
[ 105.756036] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 105.757994] I-pipe: head domain RTAI unregistered.
[ 105.758044] RTAI[hal]: unmounted.
[ 243.095661] I-pipe: head domain RTAI registered.
[ 243.095667] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 243.095714] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 243.095718] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2127938000, CPU_FREQ 2127938000
[ 243.095721] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 243.095724] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 13664000
[ 243.104188] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 243.104230] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 243.104234] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[ 243.104238] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2127938000 hz.
[ 243.104241] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 243.109923] RTAI[math]: loaded.
[ 243.270324] hm2: loading Mesa HostMot2 driver version 0.15
[ 243.272634] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 243.272676] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 243.272855] hm2/hm2_5i25.0: config.num_encoders=6, but only 2 are available, not loading driver
[ 243.272859] hm2/hm2_5i25.0: failed to parse Module Descriptor 2
[ 243.272866] hm2_5i25.0: board fails HM2 registration
[ 243.272882] hm2_pci: probe of 0000:04:00.0 failed with error -22
[ 243.508901] hm2: unloading
[ 245.617540] RTAI[math]: unloaded.
[ 245.619509] SCHED releases registered named ALIEN PEDV$D
[ 245.624801] RTAI[malloc]: unloaded.
[ 245.724031] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 245.726075] I-pipe: head domain RTAI unregistered.
[ 245.726120] RTAI[hal]: unmounted.
[ 535.816294] I-pipe: head domain RTAI registered.
[ 535.816300] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 535.816338] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 535.816342] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2127938000, CPU_FREQ 2127938000
[ 535.816345] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 535.816348] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16562750
[ 535.826566] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 535.826609] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 535.826614] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[ 535.826617] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2127938000 hz.
[ 535.826620] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 535.836340] RTAI[math]: loaded.
[ 535.997339] hm2: loading Mesa HostMot2 driver version 0.15
[ 535.999435] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 535.999477] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 535.999590] hm2/hm2_5i25.0: config.num_encoders=6, but only 2 are available, not loading driver
[ 535.999595] hm2/hm2_5i25.0: failed to parse Module Descriptor 2
[ 535.999601] hm2_5i25.0: board fails HM2 registration
[ 535.999618] hm2_pci: probe of 0000:04:00.0 failed with error -22
[ 536.234413] hm2: unloading
[ 538.346618] RTAI[math]: unloaded.
[ 538.348630] SCHED releases registered named ALIEN PEDV$D
[ 538.354081] RTAI[malloc]: unloaded.
[ 538.452031] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 538.454070] I-pipe: head domain RTAI unregistered.
[ 538.454120] RTAI[hal]: unmounted.
8 years 3 weeks ago #118573 by PCW
Replied by PCW on topic I think I'm in over my head.
As Todd mentioned, you must update the 5I25's firmware ( You seem to have 7I76 firmware installed in the 5I25 )
The actual error:
[ 535.999477] hm2_pci: discovered 5i25 at 0000:04:00.0 [ 535.999590] hm2/hm2_5i25.0: config.num_encoders=6, but only 2 are available, not loading driver [ 535.999595] hm2/hm2_5i25.0: failed to parse Module Descriptor 2 [ 535.999601] hm2_5i25.0: board fails HM2 registration [ 535.999618] hm2_pci: probe of 0000:04:00.0 failed with error -22 [ 536.234413] hm2: unloading
Is because you are using 7I76 firmware ( which only has 2 encoder available )
and a hal/ini file setup for a 7I77 ( which uses 6 encoders )
The fix is to flash the 5I25 with firmware for a 7I77:
sudo mesaflash --device 5i25 --write 5i25_7i77x2.bit
sudo mesaflash --device 5i25 --reload
The following user(s) said Thank You: Catch22
  • Catch22
  • Topic Author
  • Elite Member
  • Elite Member
8 years 3 weeks ago #118574 by Catch22
Replied by Catch22 on topic I think I'm in over my head.
OK so do I type in sudo mesaflash --device 5i25 --write 5i25_7i77x2.bit and enter, then sudo mesaflash --device 5i25 --reload and enter?
Thanks Mike
Time to create page: 0.093 seconds
