Force acis to maximise and homing sequence
7 years 9 months ago #123392 by trilobyte
i am setting up a lathe with a 7I76e. i checked the checkbox "force axis to maximise (or something like that)
but this isn't working and if i load the setting again in pncconf the checkbox is unchecked.
then there is another problem. if i set the homeing sequence x axis 1 and z axis 2. this results in 0 and -1 in the ini file?
are these known problems?
Peter
7 years 9 months ago #123393 by cmorley
What version of linuxcnc are you using?
In 2.7 it seemed to work for me.
Other then depending on the window manager AXIS is displayed minimized by default - something that I am not sure pncconf can do anything about.
also I did have to mess with the code to set AXIS to maximum.
How did you set the home sequence?
Chris M
7 years 9 months ago - 7 years 9 months ago #123401 by trilobyte
i installed the r13 debian stretch image and i'm working with the actual master release.
i have set the homeing sequence in pncconf. i tryed different things. X set to 1, Z set to 2 and at another try i set x to 0 and Z to 1.
both results in an -1 in the ini file
Peter
Last edit: 7 years 9 months ago by trilobyte.
7 years 9 months ago - 7 years 9 months ago #123402 by trilobyte
My pnccconf file and the resulting hal and ini:
schaublin125.pncconf
schaublin125.hal
schaublin125.ini
btw: i found a (cosmetic) bug in the settings for the digital outputs. they are names as Digital out 0,1,2,1 instead of 0,1,2,3
peter
7 years 9 months ago #123404 by cmorley
ok I pushed a fix for these to master.
Chris M
The following user(s) said Thank You: trilobyte
7 years 9 months ago #123422 by trilobyte
after an apt-get update, apt-get dist-upgrade i openend the config again, now it is working as expected!
tnx!
peter
Time to create page: 0.392 seconds
