Mesa 7I76E + HSS60 Driver parameters ------ losing stepps
7 years 8 months ago #126278 by MarcoGaspar
PCW wrote: Did you double the step time?
Not yet.....
This times are ok?
2500
2500
8000
12000
7 years 8 months ago #126280 by PCW
Probably not, I would double the step time and step space and try again
7 years 8 months ago #126284 by MarcoGaspar
PCW wrote: Probably not, I would double the step time and step space and try again
And 7I76e wired to the drive with dir+,dir-,puls+,puls- ?
7 years 8 months ago #126287 by PCW
Yes that should work
I think a very important thing that's often missed here is that the drive timing numbers are _minimums_, that is, they are on the edge of not working at all, because of this you should never chose drive minimums as a starting point.
The following user(s) said Thank You: MarcoGaspar
7 years 8 months ago #126308 by MarcoGaspar
PCW wrote: Yes that should work
With:
500
500
5000
1000
it works fine with mode 0 and don't lose steps
Time to create page: 0.063 seconds
