PCW wrote: pncconf should get updated when you update LinuxCNC (are you running 2.7.14?)
PCW wrote: Speed limitations will be related to hal/ini settings (or drive settings)
Can you post your hal/ini files here?
PCW wrote: [TRAJ]
AXES = 3
COORDINATES = X Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 2.50
MAX_VELOCITY = 25.00 <<<<<<<<<<<<<<<<<<<< = 1500 mm/m
