You could make a generic hal file with pncconf for a 7I92 or similar and change all the "7i92"s to "7I94"s but there's still a bit of pin name changing needed for the STMBL pins (pncconf doesn't know about STMBL drives)
I suspect you will need to get some help from someone with a working STMBL setup
