How to get 7i90hd board running?
6 years 11 months ago #150225 by viski
What should i do to get working 7i90hd + 7i48 ( 6 axis analog servo interface ) + 7i84 ( 32 input / 16 output rs422 board ) ?
Do i need to flash bit file ?
How to do it in linux ?
What to write into INI file , config line ?
6 years 11 months ago #150227 by pl7i92
hi
you shouodt go to the IRC live help channel there are people that talk to you live so it is a realtime help
at your PC and you get quick forward
6 years 11 months ago #150292 by andypugh
First work out if you have Mesaflash, then use mesaflash to see which firmware is currently on the board.
6 years 11 months ago #150466 by viski
I allways get message:" No 7i90 board find " .
i will try to connect to it with serial port
6 years 11 months ago #150480 by pl7i92
it seams the
5V isent correct
then the Jumper for the IP isent set to the value
the PC isent in the same ip area
ip a to see the pc
nmap 10.10.10.0/24 to see if there is somone responding
6 years 11 months ago #150952 by viski
Can i use 5i25 to communicate with 7i90hd ? I have it .
Time to create page: 0.183 seconds
