OK, semi success (well not really but no smoke so I've got that going for me...)
I've got axis movement, e-stop and limit switches working (x-axis limit is just hanging off the end of the machine but that's another story)
Spindle VFD powers up so the contactors etc are working but there's something wrong with my wiring on the 7i76 > VFD
Are the Opto switches supposed to be connecting ENA+ and ENA- and then DIR+ and Dir- or are they connecting the appropriate ones to the spindle signal (ie spindle - to ENA + type of thing?
When I turn the spindle on the enabled light on the VFD isn't lighting up
If I short E1 and E2 from the VFD it lights up and the motor tries to turn very slowly
*** I doubt I have the settings for the VFD in LinuxCNC so the speed of the motor is going to be out to lunch ***
Looking at some wire sample diagrams and they have the spindle + (10v I guess) connected to pins 3, 6 and 8 (spindle +, enabled + and direction +) but I think I only need the spindle + connection
but it's not clear (to me) in the manual what connection is being made on the enabled or direction on the 7i76 and I since they are opto I can't test without it being powered up (trying to keep the smoke inside for now)
Right now I think I need to connect my E1 pin to both ENA- and DIR- and then my enabled (E2) to ENA+ and dir (D) to DIR+
(or maybe vice-verse depending on the polarity of the VFD)
Does any of this make sense?
M
