7i76e not showing Field IO Ports/pins [SOLVED]
6 years 10 months ago #153659 by PCW
If you have field power and W8,W1 are in the left hand position
I would guess its a hardware issue.
I would contact Mesa and ask for an RMA# and return the card for evaluation/repair/replacement
6 years 10 months ago - 6 years 10 months ago #153661 by PCW
Normally you don't need to load any new firmware, unless you
need support for an I/O expansion daughtercard
The default, as shpiped firmware is 7i76e_7i76x1D.bit
Last edit: 6 years 10 months ago by PCW.
6 years 10 months ago #153662 by tperry
Already have an email out to them. I was afraid that might already be the case. Was hoping it was something simple. Will let you know what they come up with.
Thanks for the suggestions.
6 years 10 months ago #153686 by PCW
Do you have the Yellow field power light on? (near TB1)
6 years 10 months ago #153697 by tperry
No it is not lit. But measuring field power inputs show 24v. Thoughts?
6 years 10 months ago #153698 by PCW
TB1 pin 1 to TB1 pin 8 reads 24V?
( make sure you do not live plug or switch the DC 24V supply to the 7I76E)
