PnCConf spindle max rpm limit issue
6 years 7 months ago #161498 by cmorley
Well I can;t see how that works at all.
Can you post your config files?
6 years 7 months ago #161531 by JohnnyCNC
I have a Huanyang 24K spindle and these are my ini settings. I can't remember where I got the 16800 number from but I can run the spindle up to 400hz 24000 rpm.
[SPINDLE_0]
P = 0
I = 0
D = 0.0
FF0 = 1.00
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
OUTPUT_MIN_LIMIT = 0
OUTPUT_MAX_LIMIT = 16800
OUTPUT_SCALE = 16800
6 years 7 months ago #161616 by Dex64
Here are my config files. Ps. Don't worry about PID settings in XYZ axes I will set it later. ;) :lol:
6 years 7 months ago #161617 by Dex64
I have a Huanyang 24K too. From my config I can run too up to 24k. Physicaly spindle has 24k but in linux it's equal 6k. See my ini and screenshots
6 years 7 months ago #161652 by cmorley
Dex64 wrote: Here are my config files. Ps. Don't worry about PID settings in XYZ axes I will set it later. ;) :lol:
Hmm well you didn't mention you were using 2 ranges for spindle control.
the range scaling is all screwed up. seems if pncconf isn't calculating it correctly.
Are you actually using 2 gear ratios?
#******************* # SPINDLE S #******************* setp pid.s.Pgain [SPINDLE_9]P setp pid.s.Igain [SPINDLE_9]I setp pid.s.Dgain [SPINDLE_9]D setp pid.s.bias [SPINDLE_9]BIAS setp pid.s.FF0 [SPINDLE_9]FF0 setp pid.s.FF1 [SPINDLE_9]FF1 setp pid.s.FF2 [SPINDLE_9]FF2 setp pid.s.deadband [SPINDLE_9]DEADBAND net ratio_select.out pid.s.maxoutput setp pid.s.error-previous-target true setp pid.s.maxerror .0005 net spindle-index-enable <=> pid.s.index-enable net spindle-enable => pid.s.enable net spindle-vel-cmd-rpm-abs => pid.s.command net spindle-vel-fb-rpm-abs => pid.s.feedback net spindle-pid-out pid.s.output => scale.gear.in net gear-ratio ratio_select.out-f => scale.gear.gain setp ratio_select.in00 0.000167 setp ratio_select.in01 100.000000 net gear-select-a => ratio_select.sel0 net spindle-output <= scale.gear.out
setp ratio_select.in00 0.000167 is not right it should be 1
You haven't connect anything to gear-select-a, o the other ration won't come into affect.
How this works is the requested absolute spindle speed is multiplied by the gear scaling ration then fed to the analog output.
The analog output adds it's own scaling and limts.
What we want is 24000 (requested rpm) x 1 (gear ratio scaling ) x analog scaling = 10volt output
analog scaling works like thus:
[SPINDLE_9]OUTPUT_SCALE = what input RPM gives 10 volt output - so you want 24000 rpm request to be 10 volts - so 24000 is the scale
[SPINDLE_9]OUTPUT_MAX_LIMIT = the maximum input RPM allowed; the component will not increase voltage past this number- so 24000
[SPINDLE_9]OUTPUT_MIN_LIMIT = the minimum input RPM allowed; the component will not decrease voltage under this number - so 0
Of course you may need to tweak the OUTPUT_SCALE a bit to make up for losses/nonlinear output etc but it should be close to this.
Chris
The following user(s) said Thank You: Dex64
6 years 7 months ago #161655 by cmorley
JohnnyCNC wrote: I have a Huanyang 24K spindle and these are my ini settings. I can't remember where I got the 16800 number from but I can run the spindle up to 400hz 24000 rpm.
[SPINDLE_0]
P = 0
I = 0
D = 0.0
FF0 = 1.00
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
Was your spindle analog voltage input about 15 volts? 24000/16800 =14.3 volts
on cards like the 7i76 the spindle is controller by a digital pot working on a user selected input voltage between 5 and 15 volts rather then an analog output of +-10 volts.
Chris
Time to create page: 0.457 seconds
