Homing X and Y can't jog after homing?
6 years 6 months ago - 6 years 6 months ago #163429 by Catch22
I will take a look at this tomorrow, thank-you.
Last edit: 6 years 6 months ago by Catch22. Reason: Spelling mistake
6 years 6 months ago #163495 by Catch22
I just checked and it moves exactly .001 in both x and y but won't move anymore after that.
6 years 6 months ago #163501 by cmorley
ok that pretty much confirms my hunch.
Either your axis directions are backwards on x and y or your homing directions are backwards.
Looks like you are using shared both limits and homing, so there is no way for linuxcnc to know if you homed towards the wrong side.
Can you describe your machine or show a picture. My guess is the tool moves up and down but the table moves for x and y?
If so when you press the positive X jog key, the table should move left.
Positive Y the table should move towards you.
Is that true?
The following user(s) said Thank You: Catch22
6 years 6 months ago #163513 by Catch22
When standing in front of the mill, positive x goes to my right, positive y towards me. The table moves.
6 years 6 months ago #163514 by cmorley
ok fix the x direction.
Then as for homing which way do you want it to travel searching for home?
ie, usually I think y would home with the the table moving towards you.
6 years 6 months ago #163517 by Catch22
Ok so I have managed to get the homing all sorted out except after all 3 axis homes the x and y axis won't move when I try jogging them, the z axis jogs no problem. I'm wondering if it's not coming off of the limit switches far enough but I can't seem to find where to change that. If Infact that is the problem?
Time to create page: 0.101 seconds
