Teco FM50 and Mesa 7i77
6 years 6 months ago #164358 by Catch22
Replied by Catch22 on topic Teco FM50 and Mesa 7i77
PCW wrote: Is red AOUT5? if so you are shorting the analog out to ground
No it's black and goes to vi on the VFD.
6 years 6 months ago #164359 by PCW
Replied by PCW on topic Teco FM50 and Mesa 7i77
Was the spindle enabled?
What was the spindle speed?
When you have LinuxCNC running and the spindle
enabled and set to 1/2 speed can you post the results of
halcmd show all | grep spin
(typed in a terminal window)
6 years 6 months ago #164362 by Catch22
PCW wrote: Was the spindle enabled?
Ok I started up the spindle and the speed doesn't change until you hit 0% it stops.
I had to take pictures of the Hal file, my internet isn't working in the garage.
6 years 6 months ago - 6 years 6 months ago #164372 by PCW
Notice that you are commanding a negative spindle speed?
This will likely not work with the TECO as it probably expects 0 to 10V
_not_ -10 to +10
So to test further, select a positive spindle speed
If the TECO VFD is 0 to 10V you will need to connect the spindle
to the absolute RPM pin in hal rather than the signed RPM pin
Last edit: 6 years 6 months ago by PCW.
The following user(s) said Thank You: Catch22
6 years 6 months ago #164377 by Catch22
PCW wrote: Notice that you are commanding a negative spindle speed?
_not_ -10 to +10
Yes it looks like it's 0-10v so do I select a positive spindle speed in the Pncconfig?
6 years 6 months ago #164378 by PCW
For testing just select a clockwise spindle direction:
m3 s1000
in pncconf, uncheck the "Use +- voltage for direction" check box
_BUT_ you may want to make the changes in the hal file so you dont lose any tuning values you have adjusted
Time to create page: 0.489 seconds
