7C80 Install with wizard
03 Jul 2020 06:52 #173491
by jacky4566
7C80 Install with wizard was created by jacky4566
Sorry if this sounds dense im new here. How do I use PnCConf with the new 7C80 card? I dont have the card yet just trying to go through all the steps in a VM environment. The 7C80 does not show up under the board names options. Do I need to upgrade to version 2.9 or is there some trick here?
- Thank you received: 5925
07 Jul 2020 14:45 #173844
Replied by tommylight on topic 7C80 Install with wizard
Bumping this up.
Also moved to the correct section.
Time to create page: 0.131 seconds
