Mesaflash Generated Xml compatible with PnCConf
6 years 3 months ago #176435 by cmorley
if you look in the TEST1.hal file look for
loadrt config=" num_encoders=2 num_pwmgens=2 num_stepgens=10"
change it to:
loadrt hm2_pci config=" num_encoders=2 num_pwmgens=2 num_stepgens=10"
See of that helps
The following user(s) said Thank You: TheBigLebowski
6 years 3 months ago #176441 by TheBigLebowski
It no longer produced the error testing on a VM. I will try it out on the actual computer tomorrow.
Thank you for the help.
Time to create page: 0.092 seconds
