Y2 motor not moving during test/tune within PnCConf
5 years 11 months ago #188352 by kramerda
Added second Y motor to working 2.8 Rpi4 gantry machine. Edited with PnCConf to add Y2 motor - Mesa 7i76e setup shows 4th stepper as Y2 but with test enable it doesn't +/- jog. XYZ works, no problem. Not a hardware issue since the D542T driver and motor were swapped in/out with other axis.... wiring/hardware all OK. Since I'm testing within PnCConf (not AXIS GUI) I don't think it has anything to do with home/limit switches. Read lots of posts on tandem axis but didn't see this issue. Suggestion please?
5 years 11 months ago #188356 by PCW
I would just move ahead to running LinuxCNC
5 years 11 months ago #188359 by kramerda
will do - weird but we'll give it a try first thing tomorrow - thanks
I did read something somewhere about setting reverse direction affects step not direction signals - will check that as well.
5 years 11 months ago #188456 by kramerda
PCW - just ran LinuxCNC as you suggested and things are improving. Now only ERROR that needs a work around is "Cannot jog, home_sequence is synchronized" for joints 1 and 2 on Y axis. Based on 2.8 documents I changed the Y axis Joints 1 and 2 HOME_SEARCH_VEL and HOME_LATCH_VEL to =0 which should disable homing and allow jogging - BUT still no go. Is there a simple work around here ? Thanks,
  • Moderator
  • Moderator
5 years 11 months ago #188457 by tommylight
Home the machine before jogging
5 years 11 months ago #188459 by PCW
I think that is expected for gantry configurations (you cannot jog until homed)
Time to create page: 0.135 seconds
