No found 7i76e
5 years 9 months ago #196999 by tommylight
Replied by tommylight on topic No found 7i76e
Everything is working, so where is the issue ?
"mesaflash --device 7i76e. reply: No 7i76e board found" is normal as you are not using the default 192.x.x.x IP.
Everything is working, start pncconf and set things up, save, run LinuxCNC with the created config and watch things move.
5 years 9 months ago #197043 by chuben
Replied by chuben on topic No found 7i76e
When I do PncConfig, TB5 or TB6 does not appear to be able to configure the home and limits
5 years 9 months ago #197044 by chuben
tommylight wrote: Everything is working, so where is the issue ?
But when I do PncConfig, TB5 or TB6 does not appear to be able to configure the home and limits
5 years 9 months ago #197045 by tommylight
5 years 9 months ago #197048 by chuben
tommylight wrote:
I only get connectors 1 - 2 and 3 but not SS # 0
5 years 9 months ago #197051 by tommylight
Click on "accept components changes", the lowest button with "aceptar.......
Time to create page: 0.427 seconds
