gantry setup: X homing fine; Y-Y2 and Z not moving
  • sibelius
  • Topic Author
  • New Member
  • New Member
5 years 8 months ago #199513 by sibelius
Good evening
I manage to wire all my machine and linuxcnc does not give any error.
At this point I started to home X and everything went well; than after that I have tried to home the Y and Y2 (synchronized) and I can see from the HAL SHOW that they copy moving but physically the two motors don't make any movement.
When I power on the machine all the motor are engaged (I mean you cannot freely turning the shaft).
I m going to post my ini and hal file.
If anyone has some idea would be great.
Thanks in advance
V.
5 years 8 months ago #199519 by chris@cnc
If your stepper does not turn, but Halshow does something, it could be that your cables are incorrect or the configuration of the stepper time in ini file.
DIRSETUP = 5000 DIRHOLD = 8000 STEPLEN = 1500 STEPSPACE = 1500
In any case, increase MIN_LIMIT = -0.01 to -1. That is too close to the end position and check HOME_OFFSET = -5
The following user(s) said Thank You: sibelius
  • sibelius
  • Topic Author
  • New Member
  • New Member
5 years 8 months ago #199521 by sibelius
Thank you very much Chris
I think is the number you just posted the right one.
I ve tried to add another Pncconf to try to move the motor and one of the Y motor move in only one direction so tomorrow with a clear mind I will check the wiring and put the right number into the files.
Hopes it works otherwise i will be here again.
Your help is really precious.
Thanks again.
V.
5 years 8 months ago #199526 by Clive S
As Chris has said re:
STEPLEN = 1500
STEPSPACE = 1500
Try doubling or tripling the above
  • sibelius
  • Topic Author
  • New Member
  • New Member
5 years 8 months ago #199574 by sibelius
Morning everyone
No luck.
I checked all the wiring and everything seems ok.
What amaze me is the fact that step motor X has no problem with the same figure and Y move only in one direction.
I might try to divide more the step from 800 to 1600.
Thanks again
V.
5 years 8 months ago #199577 by tommylight
Step time and space should be 5000
-remove the connector from 7i76 X axis and insert the one from Y or Y2 or Z to test.
Time to create page: 0.285 seconds
