RPI4 + 7C81 + DMB4250-8B BreakOut Board
5 years 8 months ago #200491 by cmorley
Happy wife - happy life!
5 years 8 months ago #200507 by brianvg
Here is what I get with the --readhmid command:
mesaflash --device 7C81 --spi --addr /dev/spidev0.0 --readhmid unable to set bpw32, fallback to bpw8 Configuration Name: HOSTMOT2 General configuration information: BoardName : MESA7C81 FPGA Size: 9 KGates FPGA Pins: 144 Number of IO Ports: 3 Width of one I/O port: 19 Clock Low frequency: 100.0000 MHz Clock High frequency: 200.0000 MHz IDROM Type: 3 Instance Stride 0: 4 Instance Stride 1: 64 Register Stride 0: 256 Register Stride 1: 256 Modules in configuration: Module: DPLL There are 1 of DPLL in configuration Version: 0 Registers: 7 BaseAddress: 7000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: WatchDog There are 1 of WatchDog in configuration Version: 0 Registers: 3 BaseAddress: 0C00 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: IOPort There are 3 of IOPort in configuration Version: 0 Registers: 5 BaseAddress: 1000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: QCount There are 2 of QCount in configuration Version: 2 Registers: 5 BaseAddress: 3000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: SSerial There are 1 of SSerial in configuration Version: 0 Registers: 6 BaseAddress: 5B00 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 64 bytes Module: StepGen There are 8 of StepGen in configuration Version: 2 Registers: 10 BaseAddress: 2000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: PWM There are 2 of PWM in configuration Version: 0 Registers: 5 BaseAddress: 4100 ClockFrequency: 200.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: LED There are 1 of LED in configuration Version: 0 Registers: 1 BaseAddress: 0200 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Configuration pin-out: IO Connections for P1+Serial Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir 0 0 IOPort PWM 0 PWM (Out) 0 1 IOPort None 0 2 IOPort StepGen 0 Dir/Table2 (Out) 0 3 IOPort None 0 4 IOPort StepGen 0 Step/Table1 (Out) 0 5 IOPort None 0 6 IOPort StepGen 1 Dir/Table2 (Out) 0 7 IOPort None 0 8 IOPort StepGen 1 Step/Table1 (Out) 0 9 IOPort StepGen 2 Dir/Table2 (Out) 0 10 IOPort StepGen 2 Step/Table1 (Out) 0 11 IOPort StepGen 3 Dir/Table2 (Out) 0 12 IOPort StepGen 3 Step/Table1 (Out) 0 13 IOPort None 0 14 IOPort QCount 0 Quad-A (In) 0 15 IOPort QCount 0 Quad-B (In) 0 16 IOPort QCount 0 Quad-IDX (In) 0 17 IOPort SSerial 0 TXData0 (Out) 0 18 IOPort SSerial 0 TXData1 (Out) IO Connections for P2+Serial Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir 0 19 IOPort PWM 1 PWM (Out) 0 20 IOPort None 0 21 IOPort StepGen 4 Dir/Table2 (Out) 0 22 IOPort None 0 23 IOPort StepGen 4 Step/Table1 (Out) 0 24 IOPort None 0 25 IOPort StepGen 5 Dir/Table2 (Out) 0 26 IOPort None 0 27 IOPort StepGen 5 Step/Table1 (Out) 0 28 IOPort StepGen 6 Dir/Table2 (Out) 0 29 IOPort StepGen 6 Step/Table1 (Out) 0 30 IOPort StepGen 7 Dir/Table2 (Out) 0 31 IOPort StepGen 7 Step/Table1 (Out) 0 32 IOPort None 0 33 IOPort QCount 1 Quad-A (In) 0 34 IOPort QCount 1 Quad-B (In) 0 35 IOPort QCount 1 Quad-IDX (In) 0 36 IOPort SSerial 0 TXEn0 (Out) 0 37 IOPort SSerial 0 TXEn1 (Out) IO Connections for P7+Serial Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir 0 38 IOPort None 0 39 IOPort None 0 40 IOPort None 0 41 IOPort None 0 42 IOPort None 0 43 IOPort None 0 44 IOPort None 0 45 IOPort None 0 46 IOPort None 0 47 IOPort None 0 48 IOPort None 0 49 IOPort None 0 50 IOPort None 0 51 IOPort None 0 52 IOPort None 0 53 IOPort None 0 54 IOPort None 0 55 IOPort SSerial 0 RXData0 (In) 0 56 IOPort SSerial 0 RXData1 (In)
5 years 8 months ago #200695 by PCW
If you update mesaflash to the latest, it should print out the DB25 pin numbers in the first column.
5 years 8 months ago #200699 by brianvg
Ok, checked out the repo and built it, then it produces this output:
./mesaflash --device 7C81 --spi --addr /dev/spidev0.0 --readhmid unable to set bpw32, fallback to bpw8 Configuration Name: HOSTMOT2 General configuration information: BoardName : MESA7C81 FPGA Size: 9 KGates FPGA Pins: 144 Number of IO Ports: 3 Width of one I/O port: 19 Clock Low frequency: 100.0000 MHz Clock High frequency: 200.0000 MHz IDROM Type: 3 Instance Stride 0: 4 Instance Stride 1: 64 Register Stride 0: 256 Register Stride 1: 256 Modules in configuration: Module: DPLL There are 1 of DPLL in configuration Version: 0 Registers: 7 BaseAddress: 7000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: WatchDog There are 1 of WatchDog in configuration Version: 0 Registers: 3 BaseAddress: 0C00 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: IOPort There are 3 of IOPort in configuration Version: 0 Registers: 5 BaseAddress: 1000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: QCount There are 2 of QCount in configuration Version: 2 Registers: 5 BaseAddress: 3000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: SSerial There are 1 of SSerial in configuration Version: 0 Registers: 6 BaseAddress: 5B00 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 64 bytes Module: StepGen There are 8 of StepGen in configuration Version: 2 Registers: 10 BaseAddress: 2000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: PWM There are 2 of PWM in configuration Version: 0 Registers: 5 BaseAddress: 4100 ClockFrequency: 200.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: LED There are 1 of LED in configuration Version: 0 Registers: 1 BaseAddress: 0200 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Configuration pin-out: IO Connections for P1+Serial Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir P1 1 0 IOPort PWM 0 PWM (Out) P1 14 1 IOPort None P1 2 2 IOPort StepGen 0 Dir/Table2 (Out) P1 15 3 IOPort None P1 3 4 IOPort StepGen 0 Step/Table1 (Out) P1 16 5 IOPort None P1 4 6 IOPort StepGen 1 Dir/Table2 (Out) P1 17 7 IOPort None P1 5 8 IOPort StepGen 1 Step/Table1 (Out) P1 6 9 IOPort StepGen 2 Dir/Table2 (Out) P1 7 10 IOPort StepGen 2 Step/Table1 (Out) P1 8 11 IOPort StepGen 3 Dir/Table2 (Out) P1 9 12 IOPort StepGen 3 Step/Table1 (Out) P1 10 13 IOPort None P1 11 14 IOPort QCount 0 Quad-A (In) P1 12 15 IOPort QCount 0 Quad-B (In) P1 13 16 IOPort QCount 0 Quad-IDX (In) P5 3,6 17 IOPort SSerial 0 TXData0 (Out) P6 3,6 18 IOPort SSerial 0 TXData1 (Out) IO Connections for P2+Serial Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir P2 1 19 IOPort PWM 1 PWM (Out) P2 14 20 IOPort None P2 2 21 IOPort StepGen 4 Dir/Table2 (Out) P2 15 22 IOPort None P2 3 23 IOPort StepGen 4 Step/Table1 (Out) P2 16 24 IOPort None P2 4 25 IOPort StepGen 5 Dir/Table2 (Out) P2 17 26 IOPort None P2 5 27 IOPort StepGen 5 Step/Table1 (Out) P2 6 28 IOPort StepGen 6 Dir/Table2 (Out) P2 7 29 IOPort StepGen 6 Step/Table1 (Out) P2 8 30 IOPort StepGen 7 Dir/Table2 (Out) P2 9 31 IOPort StepGen 7 Step/Table1 (Out) P2 10 32 IOPort None P2 11 33 IOPort QCount 1 Quad-A (In) P2 12 34 IOPort QCount 1 Quad-B (In) P2 13 35 IOPort QCount 1 Quad-IDX (In) P5 TXEN 36 IOPort SSerial 0 TXEn0 (Out) P6 TXEN 37 IOPort SSerial 0 TXEn1 (Out)
Which looks very much like what I expect. I suppose I will need to generate the configuration, and then besides changing the board name and the command, I will need to also change the pin mappings after I run through pncconf. Still not really sure what I need to enter and where in pncconf.
Thanks,
Brian
