Spindle - 7i76e
5 years 6 months ago #204577 by andypugh
Replied by andypugh on topic Spindle - 7i76e
Fiury wrote: Is any difference , which is IN and OUT for watter ? Or orientation of spindle (i had it on floor- flat)
It flows tru then thought that it is ok :-(
It should have been OK, yes.
Perhaps you were running it at too low a speed?
5 years 6 months ago - 5 years 6 months ago #204598 by Fiury
Replied by Fiury on topic Spindle - 7i76e
I runned about 300-500rpm about 1 min without watter, then i start cooling (1min) then i started spindle and in 15 sec for about 8000 rpm was KO.
If you have idea why it was burned ? To avoid to burn next spindle..
a) spindle cann´t be horizontaly , must be verticaly ?
b) is difference IN /OUT wotter on spindle ? I don´t think so watter flowing thru..
c) some next setting on VDF ?
I had thisone www.aliexpress.com/item/32695905414.html...3.0.0.4e136326rt8vVc , i will probaby order next, but not so rich to burn one by one :) , need some help why..
With VFD Huanyang 2,2 kW..
Last edit: 5 years 6 months ago by Fiury.
5 years 6 months ago #204624 by Mike_Eitel
Replied by Mike_Eitel on topic Spindle - 7i76e
In any case:
Ask the seller.
Describe that it was without load.
Minimum speed 300-500.
Ask if position must be vertical
Ask what max temperature water has to come Out. (not in)
5 years 6 months ago #204627 by Clive S
Replied by Clive S on topic Spindle - 7i76e
Has this ever run with the parameters before.
Have you check the number of poles some of these vfd's come with them set at 2 or 4 if I am not mistaken I think they should be set for 2 PD143
5 years 6 months ago - 5 years 6 months ago #204729 by Fiury
Clive S wrote: Has this ever run with the parameters before.
4 is set default of VDS. This parametr i did not changed :´-(
Taday i ant to start mill oak glued beams, for this machine .... and nothing....
5 years 6 months ago #205312 by Fiury
Can someone post setup VDF for :
2,2 kW HY inverter and 2,2 kW watter spindle:
Then Configure the VFD
PD001 = 1 (external terminal)
PD002 = 3 (which was not in manual)
PD044 = 1 (for RUN)
PD045 = 5 (DIR.......FOR /REW)
other PD* ?
I don´t want to burn next spindle.. :/
Thank you very much
Time to create page: 0.082 seconds
