Can't find how to install and run pncconf wizard
5 years 5 months ago #207841 by karoria
Hi all,
I am very new to linuxcnc world. I have raspberry pi 4 8gb and mesa 7i96 ethernet card from which I want to make cnc mill. I tried pre-installed raspbian image but unable to run pncconf wizard successfully till end. Later I found that the pre-installed raspbian image has known issue not running with pi4 8gb board. So, I have installed linuxcnc with clean raspbian image with command line. Now, I can't figure out how to install and start pncconf wizard.
Waiting desperately for help. Thanks in anticipation.
Best,
Ravi
5 years 5 months ago #207857 by AgentWD40
Have you tried typing in
pncconf
Into the terminal after installing linuxcnc?
The following user(s) said Thank You: karoria
5 years 5 months ago #207882 by andypugh
pncconf is included in the LinuxCNC package.
Did you install the package, or compile from source?
Which kernel did you install?
5 years 5 months ago #208131 by karoria
Sorry for late reply. Actually after I wrote for help here, I could not connect my usb keyboard/mouse as usb ports were disabled. I have already flashed pre-made image 3 to 4 times but not luck. Now I will try using fresh install from scratch image of raspberry pi os.
Kindly let me know in case a working solution for RPi4 8gb RAM is already available. I am open to install ubuntu desktop or 64 bit raspberry pi os if that helps.
5 years 5 months ago #208319 by karoria
Update... I bought rpi4 4gb and flashed os with the pre-built linux cnc rpi4 image. Now everything seems to work fine. I will play with settings and ui now. Thanks for support.
Time to create page: 0.244 seconds
