- Thank you received: 6
he Home_Search_Vel is marked as -1.000 in the INI but the PNCCONF is showing 60.000. I don't know enough to know if these should match and if it makes a difference. I do know that when I home the axis, it moves at a speed that seems about right.
Maybe I'm thinking about this wrong, but I'd expect the axis to hit the limit switch and then back off on its own so the machine is usable. This would also set the proper coordinates for the machine.
To me, it seems like HOME_IGNORE_LIMITS = YES is being ignored.
And that just clicked for me. I had checked that the e-stop wasn't being triggered with halshow, but I hadn't looked closely to confirm that the limit switches were triggering the axis I thought they were. A quick fix to swap the pins in PNCCONF and the axis homed no problem.LinuxCNC will ignore the limit switch input for this joint while homing. This setting will not ignore limit inputs for other joints.
I have to disagree. It can be better/easier/faster to edit the files directly, but PNCCONF has context and explanations that for a novice like myself make it easier to set up a configuration. Running through a config program once does not make me an expert enough to understand the shorthand used in the INI file.It's late here. Once you have used Pncconf it is better to hand edit the hal and ini files by hand ie. It IS the hal and ini files that are in the config folder that are used. If you then try and use Pncconf again it will over write them.
