How to find the right Step Time/Step Space?
2 years 6 months ago - 2 years 6 months ago #297639 by visharc
Hello !!
i am new here i also had a question about this i have attached a photograph from my driver's manual but not sure what to conclude about
step time
Step space
direction hold
Direction setup
Can you please help me
Last edit: 2 years 6 months ago by visharc.
2 years 6 months ago #297642 by PCW
The specifications miss the minimum step pulse high
time and direction hold time but this should work:
Steptime = 5000
Stepspace = 5000
Dirsetup = 130000
Dirhold = 130000
Note that the picture shows active low
step pulses so make sure you invert
the step outputs (LinuxCNC default is active high)
The following user(s) said Thank You: visharc
2 years 6 months ago #298125 by visharc
Thank you its working fine !!
2 years 5 months ago - 2 years 5 months ago #301812 by RBCnc
can you help with stepper timing the terms are a little different. im using mesa 7i76s and TMC2160 driver. works ok now but growls a little
Last edit: 2 years 5 months ago by RBCnc. Reason: borked attachment
Time to create page: 0.063 seconds
