these were my suspects for the last couple of weeks yet, but trying anything i could think of - i just couldn't get any different result so far.Wiring and timing, set timings to at least 5000 both for step and 20000 both for dir.
"it just "spits" what feels like a single step (or not much more) at the end of the commanded movement. and no matter if clicking + or - it's always the same direction"
This sounds a lot like step/dir being swapped...
Also if you are using a 7I92 without a breakout board
there is really only one type of connection that makes
sense: +5V to drives STEP+ and DIR+, Drives STEP-
and DIR- to 7I92 step/dir pins. And then set the step
polarity to active low.
that's what i came to understand in the meantime - that the 7i92 only seems to be meant as a 'gateway' between computer and other mesa-cards. interpreting your suggestion with my basic electronics knowledge i assume you mean to protect the mesa-card from currents flowing back from the machine/motors, right? not sure how likely this could happen with my rather 'light' machine, but i'll keep it in mind.Note that I do not recommend connecting motor drives directly
tp the 7I92 but it can be done if you are careful no only connect
the 7I92 IO pins to OPTO isolated signals
