Note that I do not recommend connecting motor drives directly
tp the 7I92 but it can be done if you are careful no only connect
the 7I92 IO pins to OPTO isolated signals
You are not right, not yet !i'm measuring constant 5V on the pairs which should output step/dir as soon as i start linuxcnc. am i right assuming these pins are unrecoverably busted?
could someone please clarify what 'with pin1s connected' means?Note: 26 pin header P1 will match standard parallel port pin-out if terminated with flat cable 26 pin receptacle/DB25F cable with pin1s connected (and header pin 26 left open)
