laser add on to gantry mill
5 years 1 month ago #220757 by ericg
I have another thread about this but not sure it was the best place, anyway I added a 2.5w laser to my router and changed my preprocessor to use M3 Sxxxx to control intensity and it's all working quite well, BUT I noticed gaps and overburn in my images especially outline text. It seems that the laser is slow to turn on when XY moves leaving a gap and slow to turn off when starting a rapid move leaving a slight burn trail. (slow being a relative term)
Tommylight suggested upping the Z velocity and acceleration but that did not seem to help.
Can anyone suggest a fix (if possible) I don't know if its hardware (which is a crappy l-cheapo laser, bottom of even their line) or software, say in the trajectory planner.
I have a Mesa 5i25 (no 7i76 etc) driving a Gecko g540 so I have no access the hm2_5i25.0.pwmgen.00.pwm output as I would have in a stepconfig layout (or please correct me if I have this completely wrong)
Eric
5 years 1 month ago #220759 by PCW
Replied by PCW on topic laser add on to gantry mill
You have another accessible PWM gen on the second 5I25 connector
5 years 1 month ago #220761 by ericg
Replied by ericg on topic laser add on to gantry mill
I have ordered a cable to suit the P2 socket for this reason, but won't I have the same issue? how would I run that through motion.analog-out-00, would something like
net analogout motion.analog-out-00 => hm2_5i25.1.pwmgen.00.value
net spindle-enable => hm2_5i25.1.pwm.00.enable
and use G68 E1 Q1 in the pre processor work ??
any guidance appreciated
Eric
5 years 1 month ago #220762 by PCW
I think what tommylight was suggesting was to use the z position to set the PWM value
rather than spindle, since the z value would be synchronized with motion and spindle speeds are not
5 years 1 month ago #220764 by ericg
Thanks I'll re read tommylights files but I'm still not grasping how to use the mesa card pwmgen as opposed to the software one, I need an example (if I'm not asking too much) on how to use the mesa card pwmgen output with motion.analog-00-out.
apologies for being so dim.
my limited understanding is that the software generated pwmgen has a pwmgen.0.pwm output but the mesa card one does not. I haven't seen one mentioned anywhere so please correct me as required.
Eric
5 years 1 month ago #220801 by PCW
If you are using a G540, the first hardware PWMgen (pwmgen.00) will connect
to the G540s spindle analog circuit but the second pwmgen (pwmgen.01)
will connect to the unused 5I25 expansion connector.
Time to create page: 0.062 seconds
