EPP 7I43
5 years 1 day ago #224740 by andypugh
Replied by andypugh on topic EPP 7I43
The problem seems to be here:
github.com/LinuxCNC/linuxcnc/blob/2b37c8...onf/pncconf.py#L3838
It seems to be a mismatch between signal names and what is being checked for.
A workaround would be to edit the file (it's Python so you can just do that) to simply set pwm = True in the line underneath the "if" and it should work.
(Definitely looking like a bug)
5 years 1 day ago #224782 by lendrum
Replied by lendrum on topic EPP 7I43
No joy. It is still doing the same.
5 years 13 hours ago #224849 by cmorley
Replied by cmorley on topic EPP 7I43
Is this using linuxcnc's 7i43 firmware or something else?
What version of linuxcnc are you using?
4 years 11 months ago #224942 by lendrum
It is not a bug. It is a moron. I did not have the 5v supply connected to the 7i43.
4 years 11 months ago #224951 by cmorley
glad you figured it out - it's happened many times before :)
Time to create page: 0.369 seconds
