Who said that you have to use all existing outputs to hook them up to common, no you don't need to do that. It is sufficient that for example 2-3 out of 10 are powered or 2 out of 5 or whatever, because powered pins are a must on every board, they are absolutely needed while it is absolutely not a big deal to use an external SSR when needed and in fact that is a much better practice because 2A internal ssr rating is not even good for phone charging, pretty useless anyways.
Or just adding a couple of powered ones on top isn't really that big of a deal and is not even any extra cost, and for the heck of it, if it would make a board $5 more expensive than it already is, would it make it a deal breaker for buyers? I doubt it. And by using an external SSR you are getting a way beefier SAFER in this case SSR relay that can be any type you need (DC or AC or whatever C), which I did many times and that did not feel half assed at all, unlike this solution on my mesa board, where you left wondering why the heck there are ZERO powered signal outputs to the extent where you cant even natively connect ENA pins on your driver.
Just by quick estimate I can tell this board costs about $15 (I produced boards before in bulk) or less to manufacture, imagine how much profit there is already and they cant even add a basic feature for $0.50 extra for their consumers. As I said, corporations are all the same.
