Mesa 7i92 with 7i77 . No PWM after flashing bit file
4 years 10 months ago #228743 by DeRooij TSC
I will try to post those tomorrow. Bed time for now over here...
Thanks so far!
4 years 10 months ago #228829 by DeRooij TSC
So I copied the hall and ini file, but I'm on  windows PC right now. I hope this works?
4 years 10 months ago #228832 by PCW
Looks basically ok except that you have "num_pwmgens= 3"
which should cause an error since a 7I77 configuration would not normally
have any pwmgens.
I would disconnect the 7I77 analog out from the drives and monitor
x-output (with halmeter or halshow) as you jog back and forth
and verify if the 7I77 analog output matches x-output
(with a P of 5 you would expect a analog output voltage of 5V per MM
of following error)
4 years 10 months ago #228860 by Clive S
Not related to your problem. But I see a small problem with the ini file. Generally the axis and joint should be the same.
[AXIS_X]
MIN_LIMIT = -0.01
MAX_LIMIT = 200.0
[JOINT_0]
MIN_LIMIT = -200
MAX_LIMIT = 200.0
[AXIS_Z]
MIN_LIMIT = -100.0
MAX_LIMIT = 0.01
[JOINT_1]
MIN_LIMIT = -100.0
MAX_LIMIT = 200
4 years 10 months ago #228861 by DeRooij TSC
We have movement! I must be colorblind. Made a correct wiring diagram but switched the two analog wires like you mentioned. Z axis is jogging between its software limits now. Not tuned yet though. X axis is not moving, doesn't get analog signal. I tried another channel, no change. When I manually put X in another position and I start Linux, X forces itself to 0,000mm on the DRO and stays there. But also no drift anymore.
Time to create page: 0.070 seconds
