Dual motors aren't stepping in sync
4 years 10 months ago - 4 years 10 months ago #230168 by AgentWD40
I figure this is a config issue, but I wasn't sure if I should post here or in plasmac.
I was running Linux Mint + LinuxCNC 2.9 + PlasmaC installed over a year ago. Config was working.
Today I reformatted the hard drive and installed LinuxCNC using the ISO from the linuxcnc website, I then upgraded to buildbot's linuxcnc 2.9 and used pncconf to setup QTPlasmC.
My machine is XYYZZ, that is two Y motors and two Z motors. I have no limit switches. The gantry is simply pushed against hard stops at a known location before powering up the machine. I'm using a 7i96
1. How can I configure a button in QTPlasmaC that in a single click will simply HOME all three axis to x=0, y=48, z=0 ? This worked in my old Axis+PlasmaC config
2. When I push home buttons in the QTPlasmaC interface I'm not sure if Y2 and Z2 are homed? Anyway, after click home buttons when I try to move the Y or Z axis it appears only Y1 or Z1 will move respectively.
I've attached my preliminary hal and ini files for reference.
Last edit: 4 years 10 months ago by AgentWD40.
4 years 10 months ago - 4 years 10 months ago #230172 by AgentWD40
I've noticed that the HOME_SEQUENCE values are not being saved in the ini file... or am I missing something?
In my old config I set them to 0 for all 5 joints, but after looking at the docs I'm wondering if being -1 would be better. Either way, pncconf isn't saving my home sequence values.
[EDIT]
Also it seems that pncconf isn't allowing negative values in the home sequence field of the gui, but given the documentation I think they should be supported or otherwise some sort of mechanism to support dual motor axis in the gui. right? linuxcnc.org/docs/html/config/ini-homing.html#_home_sequence
[EDIT x2]
Can confirm that pncconf.py lines 4149 and 4340 that absolute value is being taken of "homesequence"
Also, the saved .pncconf file shows sequence values of type float instead of int
4 years 10 months ago #230198 by cmorley
I see no limit switch inputs in your config. I beleive pncconf expects limit switches to set up home sequence. Without home switches home sequence doesn't make sense.
4 years 10 months ago #230199 by AgentWD40
Yea no limit switches.
The assumption is that the machine will always power up at a known position against hard stops.
4 years 10 months ago #230200 by tommylight
On the link about homing, see section 6.13.
The following user(s) said Thank You: AgentWD40
4 years 10 months ago #230202 by cmorley
That's outside pncconf's programming.
Time to create page: 0.348 seconds
