PID
4 years 9 months ago #230877 by Bahaa_Asem
PID was created by Bahaa_Asem
Hello there, I need advices for just how to adjust a cart that just moves in a short single horizontal line? I'm just a beginner...
4 years 9 months ago #230953 by tommylight
4 years 9 months ago #232667 by Bahaa_Asem
Replied by Bahaa_Asem on topic PID
The system is not stable at all when I try values for PID, and I left these parameters at their default values:
Max. Output:10
Min. Output:-10
Output scale:10
Do they need to be changed?
4 years 9 months ago - 4 years 9 months ago #232829 by Todd Zuercher
Replied by Todd Zuercher on topic PID
Is this an analog controlled servos? (Mesa step/dir setups have PIDs to but they don't need tuning.)
Normally those output settings don't really need to be adjusted.
Do you know how to use Halscope to monitor the feedback while you tune your PID loop?
Do you know what kind of command the drive is expecting as an input? (torque, velocity, postion)
Last edit: 4 years 9 months ago by Todd Zuercher.
4 years 9 months ago #232847 by cmorley
Replied by cmorley on topic PID
and that's not PID settings - they are analog voltage range and scaling
PID settings for servo ill definitely need adjustment.
4 years 9 months ago #233494 by Bahaa_Asem
yes it's analog, and we use velocity controlled mode
when I just enable the servo(without giving motion commands) this appears to me on the Halscope
ibb.co/XWj9Th3
and the value of the last two decimal digits i.e. y=0.0xx fluctuates.
is it just a noise problem?can it be fixed by EMI filter?, or something else causing the problem?
Time to create page: 0.316 seconds
