Segmentation Fault
4 years 9 months ago #231507 by FlashPackets
 halrun -k -v
halcmd: loadrt hostmot2
/usr/bin/halrun: line 159: 13776 Segmentation fault      $INTERACTIVE
Note: Using POSIX realtime
There is no joy in Leadville, any advice on dealing with this?
4 years 9 months ago #231525 by tommylight
Replied by tommylight on topic Segmentation Fault
Not much to go on ...
More info.
4 years 9 months ago #231576 by FlashPackets
Replied by FlashPackets on topic Segmentation Fault
That's what I thought.
Can this problem result from an incomplete HAL file?
I'm trying to get a 7i92h up and humming.
4 years 9 months ago #231585 by Todd Zuercher
Replied by Todd Zuercher on topic Segmentation Fault
Sounds something like a corrupted file from a bad download or failing hardware (like a dying HD.)
4 years 9 months ago #231629 by FlashPackets
After a day of experimentation it seems that the origins of the SEGFAULT are the result of trying to have more than one instance of halcmd.
So if I should type
halcmd show all
it will run on the command line and exit
and then
halcmd loadrt hostmot2
it SEGFAULTS as it was already running as a deamon process.
At least that's what seems to be happening.
Time to create page: 0.318 seconds
