Hello guys!
The 7i96 working fine, i can mooveing with axis and spindle. I made a ladder to hidraulic, lube, EMG and many options. Its working.
But the 7i96 card's ENA 0-3 outputs dont working. If i control ENA0 to ON, ENA 1-3 switch with than to ON. I check it on the HAL pins, only 00 output switched to 1. I think its a problem with my 7i96 board a damaged chip or optocouplers. Because i lost 4 output on my config i need more IO. I used 7i80. I can set the IP numbers 192.168.1.121 7i96 and 192.168.1.123 7i80HD.
my hal config works only 7i96, and i see the 7i80HD on HAL pin window.
I switch a config on 7i80 with mesaflash to Just IO .bit
So my problem now, i dont know how can i use this GPIO -s to output. I try use setp hm2_7i80.0.gpio.00 is_output and try on and off the output.. but the 00 IO pin have only 5V. How can i wiring the GPIO to output or input and how can is set it on my .hal file?
