7i76e with PWM, 4 step gen AND TB5 and TB6
4 years 5 months ago #242551 by koopa
I guess I can write a script to find/replace 7i76/7i76e in the file to be able to keep using pncconf.
4 years 5 months ago #242552 by PCW
Did you enter 7i76 rather than 7i76e on the discovery page?
Also rather than editing every name, use pncconfs card name substitution
option (so the card name is only present once in the ini file)
4 years 5 months ago #242553 by koopa
INI file did the trick. At least just 1 spot to change.
I think when I did the discover I entered "7i76e-16", let me try it again.
4 years 5 months ago - 4 years 5 months ago #242554 by koopa
Ah,
[code]greg@cutty:~/linuxcnc/configs/shapeoko$ mesaflash --device 7I76E-16 --addr 10.10.10.10 --readhmid [code]ETH device 7I76E-16 at ip=10.10.10.10 7I76E-16 Configuration Name: HOSTMOT2 General configuration information: BoardName : MESA7I76 pncconf probably picked the board name up from there?
Is this a result of flashing 7i76e_7i76x1pD.bit?[/code][/code]
Last edit: 4 years 5 months ago by koopa.
4 years 5 months ago #242555 by PCW
No, on Ethernet cards the name is not the FPGA/HM2 name (MESA7I76)
Did you try "7I76E" with the discovery option? it works for me
4 years 5 months ago #242640 by koopa
Running 2.8.2 iso
If I enter "7i76e" when asked, it will say "Boardname: discovered:7i76". I then have to enter the number of connectors, number of pins and interface type.
Time to create page: 0.146 seconds
