[YES]Is there a way to create/generate firmware .xml from an existing .pin file?
4 years 3 months ago #248697 by andypugh
Q. Is there some way to generate an .xml file from a .pin file?
You can get an XML file based on the actual installed hardware, which might actually be better?
sudo mesaflash --readhmid --xml --device 5i25 > test.xml
For example.
4 years 3 months ago #248706 by cmorley
Mesaflash generated XMLs probably won't work properly in pncconf unfortunately - but you can try.
4 years 2 months ago #250793 by Andreas_Rackow
mesaflash XML won't work.
Advanced option, pinfile in the help/input, discoveryoptions, read 'read hostmot2 PIN file from help's input tab. Done worked for me all the time.
Time to create page: 0.083 seconds
