Let me explain further, my MESA 767ie expansion connectors are connected with CNC4PC's C25 breakout board, that is the external button lines go through 74HC14N IC first before entering to Mesa card
Having further done the followings but all in vain (that is the cycle start button still turns on itself):
> setp deounce.0.delay15~150 and letting those gpio's input to and go out of them
> adding 47k ohm pull up resistor on those pins
> adding two 0.1uF capacitors on each those pins
Before using the Mesa card and LinuxCNC these couple of years, I used to use Mach3 Ethernet SmoothStepper card for a long time, it haven't this noise interference problem. For the Mesa card, is it really this problem this time?
As I have done all the hardwares: include building the keyboard pcb, key button switches and panel housing building. Those external buttons are of momentary switch type. I might need to change all of them. Change to normal closed type, that is they are normally at 0V voltage level, so the randomly positive voltage noise don't affect those input lines. Will this method work? Not yet test and i don't know? Please advise? There is no momentary switch of normal close type, I need to change them to toggle switches (2 positions spring back type) or limit switch (as it has NO and NC position for selection to use) but need to add separate piece of plastic button cap on top of it...Anyway, trouble...
Thanks for the reading, my English is not good
