Stepgen spindle
4 years 2 months ago - 4 years 2 months ago #249997 by PCW
Replied by PCW on topic Stepgen spindle
[SPINDLE_0]
MAX_VELOCITY = 104.16666666666667
MAX_ACCELERATION = 400.0
STEPGEN_MAXVEL = 130.21
STEPGEN_MAXACCEL = 500.00
P = 100.0   <<<<<<<<<<<<<<<<< I would set this to 0 and not worry about encoder feedback yet
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 4700.0
ENCODER_SCALE = 1000.0 <<<<<<<<<<<<<<<<<<<<< if you have 10000 counts per turn, this must be 10000
# these are in nanoseconds
DIRSETUP   = 5000
DIRHOLD    = 5000
STEPLEN    = 2500
STEPSPACE  = 2500
STEP_SCALE = 1000.0  <<<<<<<<<<<<<<<<<<<<< if you have 10000 steps per turn, this must be 10000
Last edit: 4 years 2 months ago by PCW.
4 years 2 months ago #250013 by gilesclement
Replied by gilesclement on topic Stepgen spindle
Ok, thank you. The Max_Output would then be the maximum speed of the motor (3000rpm) or the max speed of the spindle after the pulley ratio?
And will Max acceleration also control deceleration?
4 years 2 months ago #250018 by PCW
All speed settings should be for the output at the spindle so instead of 10000
for the step scale, it should be 10000*motor_speed/spindle_speed
The stepgen acceleration settings will determine the spindle ramp rate
(in RPS/S)
Time to create page: 0.048 seconds
