- Thank you received: 5334
7i97 configuration utilities that actually work ?
4 years 2 weeks ago #254233
Replied by PCW on topic 7i97 configuration utilities that actually work ?
Do you have the proper firmware installed in the 7I97?
( 7i97_7i76d.bit )
This is required as a first step
Once this is done and the 7I76D is connected and powered you can list
all available I/O points with:
halcmd show pin hm2
(when linuxCNC is running)
At this point, for simple I/O you just need to connect linuxCNC pins to I/Os pin in hal,
basically a set of
net somesignalname linuxcnc_pin 7i76IO_pin
statements
( 7i97_7i76d.bit )
halcmd show pin hm2
basically a set of
statements
- smc.collins
- Topic Author
- Thank you received: 139
4 years 2 weeks ago #254246
by smc.collins
Replied by smc.collins on topic 7i97 configuration utilities that actually work ?
I am wiring up the last bits today and making the required documentation to sit down and do the configuration. I need things that are probably a bit more complex than connecting pins however.
I need my hydraulic power unit to power down when the machine isn't running. I need the controls to wait until pressure is at the proper value " I have pressure sensors" etc
I have a 2 speed gear box with confirmation switches and a BCD switch array hydraulic turret which I am sure will need timing adjustments to get working properly.
It's more a time rather than a ability thing for me at the moment. I just can't spare the time I need to learn everything I need to learn at this moment to do this configuration on my own. I have some personal matter I have to deal with and 3 more sick machines behind this one to get up and running parts for the new bicycle business. We lost access to our foreign vendor for machine work.
As I said, I am willing to pay someone to help me get this machine up and running, if you need some $$$$ for your time that's absolutely understandable. I am not asking anyone to work for free. I can send the configuration of the hardware attached. I am fleshing out the basics of the configuration today. Drive enables, encoders etc.
I am sure I can handle the tuning and calibration side. It's the amount of functions this machine has which leave me feeling uneasy, and if it crashes, it won't be cheap to fix.
If you can't or don't have time, please refer me to someone who does. This is a very hot issue for me at the moment.
