7i97+8i20 error function not found
3 years 10 months ago #259860 by saquzi
what does:
halcmd show all hm2
report?
saquzi@debian:~$ halcmd show all hm2
Loaded HAL Components:
ID Type Name PID State
26 RT hm2_eth ready
Component Pins:
Owner Type Dir Value Name
26 s32 OUT 2098000000 hm2_7i97.0.0.debug
26 float IN 0.03125 hm2_7i97.0.8i20.0.0.angle <== motor.00.angle
26 float OUT 55.04 hm2_7i97.0.8i20.0.0.bus-voltage
26 float OUT 24 hm2_7i97.0.8i20.0.0.card-temp
26 float IN 0 hm2_7i97.0.8i20.0.0.current <== motor.00.current
26 bit OUT FALSE hm2_7i97.0.8i20.0.0.fault.U-current
26 bit OUT TRUE hm2_7i97.0.8i20.0.0.fault.U-current-not
26 bit OUT FALSE hm2_7i97.0.8i20.0.0.fault.V-current
26 bit OUT TRUE hm2_7i97.0.8i20.0.0.fault.V-current-not
26 bit OUT FALSE hm2_7i97.0.8i20.0.0.fault.W-current
26 bit OUT TRUE hm2_7i97.0.8i20.0.0.fault.W-current-not
26 bit OUT FALSE hm2_7i97.0.8i20.0.0.fault.bus-high
26 bit OUT TRUE hm2_7i97.0.8i20.0.0.fault.bus-high-not
26 bit OUT FALSE hm2_7i97.0.8i20.0.0.fault.bus-overv
26 bit OUT TRUE hm2_7i97.0.8i20.0.0.fault.bus-overv-not
26 bit OUT FALSE hm2_7i97.0.8i20.0.0.fault.bus-underv
26 bit OUT TRUE hm2_7i97.0.8i20.0.0.fault.bus-underv-not
26 bit OUT FALSE hm2_7i97.0.8i20.0.0.fault.framingr
26 bit OUT TRUE hm2_7i97.0.8i20.0.0.fault.framingr-not
26 bit OUT FALSE hm2_7i97.0.8i20.0.0.fault.module
26 bit OUT TRUE hm2_7i97.0.8i20.0.0.fault.module-not
26 bit OUT FALSE hm2_7i97.0.8i20.0.0.fault.no-enable
26 bit OUT TRUE hm2_7i97.0.8i20.0.0.fault.no-enable-not
26 bit OUT FALSE hm2_7i97.0.8i20.0.0.fault.overcurrent
26 bit OUT TRUE hm2_7i97.0.8i20.0.0.fault.overcurrent-not
26 bit OUT FALSE hm2_7i97.0.8i20.0.0.fault.overrun
26 bit OUT TRUE hm2_7i97.0.8i20.0.0.fault.overrun-not
26 bit OUT FALSE hm2_7i97.0.8i20.0.0.fault.overtemp
26 bit OUT TRUE hm2_7i97.0.8i20.0.0.fault.overtemp-not
26 bit OUT FALSE hm2_7i97.0.8i20.0.0.fault.watchdog
26 bit OUT TRUE hm2_7i97.0.8i20.0.0.fault.watchdog-not
26 bit OUT FALSE hm2_7i97.0.8i20.0.0.status.brake-old
26 bit OUT TRUE hm2_7i97.0.8i20.0.0.status.brake-old-not
26 bit OUT FALSE hm2_7i97.0.8i20.0.0.status.brake-on
26 bit OUT TRUE hm2_7i97.0.8i20.0.0.status.brake-on-not
26 bit OUT FALSE hm2_7i97.0.8i20.0.0.status.bus-underv
26 bit OUT TRUE hm2_7i97.0.8i20.0.0.status.bus-underv-not
26 bit OUT FALSE hm2_7i97.0.8i20.0.0.status.current-lim
26 bit OUT TRUE hm2_7i97.0.8i20.0.0.status.current-lim-not
26 bit OUT FALSE hm2_7i97.0.8i20.0.0.status.ext-reset
26 bit OUT TRUE hm2_7i97.0.8i20.0.0.status.ext-reset-not
26 bit OUT FALSE hm2_7i97.0.8i20.0.0.status.no-enable
26 bit OUT TRUE hm2_7i97.0.8i20.0.0.status.no-enable-not
26 bit OUT TRUE hm2_7i97.0.8i20.0.0.status.pid-on
26 bit OUT FALSE hm2_7i97.0.8i20.0.0.status.pid-on-not
26 bit OUT FALSE hm2_7i97.0.8i20.0.0.status.sw-reset
26 bit OUT TRUE hm2_7i97.0.8i20.0.0.status.sw-reset-not
26 bit OUT FALSE hm2_7i97.0.8i20.0.0.status.wd-reset
26 bit OUT TRUE hm2_7i97.0.8i20.0.0.status.wd-reset-not
26 float IN -50 hm2_7i97.0.dpll.01.timer-us
26 float IN 100 hm2_7i97.0.dpll.02.timer-us
26 float IN 100 hm2_7i97.0.dpll.03.timer-us
26 float IN 100 hm2_7i97.0.dpll.04.timer-us
26 float IN 1 hm2_7i97.0.dpll.base-freq-khz
26 u32 OUT 0x0000002A hm2_7i97.0.dpll.ddsize
26 float OUT 11.09653 hm2_7i97.0.dpll.phase-error-us
26 u32 IN 0x00400000 hm2_7i97.0.dpll.plimit
26 u32 OUT 0x00000018 hm2_7i97.0.dpll.prescale
26 u32 IN 0x000007D0 hm2_7i97.0.dpll.time-const
26 s32 OUT 0 hm2_7i97.0.encoder.00.count
26 s32 OUT 0 hm2_7i97.0.encoder.00.count-latched
26 bit I/O FALSE hm2_7i97.0.encoder.00.index-enable
26 bit OUT TRUE hm2_7i97.0.encoder.00.input-a
26 bit OUT TRUE hm2_7i97.0.encoder.00.input-b
26 bit OUT FALSE hm2_7i97.0.encoder.00.input-index
26 bit IN FALSE hm2_7i97.0.encoder.00.latch-enable
26 bit IN FALSE hm2_7i97.0.encoder.00.latch-polarity
26 float OUT 0 hm2_7i97.0.encoder.00.position ==> motor.00.pos-fb
26 float OUT 0 hm2_7i97.0.encoder.00.position-latched
26 bit OUT FALSE hm2_7i97.0.encoder.00.quad-error
26 bit IN FALSE hm2_7i97.0.encoder.00.quad-error-enable
26 s32 OUT 0 hm2_7i97.0.encoder.00.rawcounts
26 s32 OUT 0 hm2_7i97.0.encoder.00.rawlatch
26 bit IN FALSE hm2_7i97.0.encoder.00.reset
26 float OUT 0 hm2_7i97.0.encoder.00.velocity ==> motor.00.vel-fb
26 float OUT 0 hm2_7i97.0.encoder.00.velocity-rpm
26 s32 OUT 0 hm2_7i97.0.encoder.01.count
26 s32 OUT 0 hm2_7i97.0.encoder.01.count-latched
26 bit I/O FALSE hm2_7i97.0.encoder.01.index-enable
26 bit OUT FALSE hm2_7i97.0.encoder.01.input-a
26 bit OUT FALSE hm2_7i97.0.encoder.01.input-b
26 bit OUT FALSE hm2_7i97.0.encoder.01.input-index
26 bit IN FALSE hm2_7i97.0.encoder.01.latch-enable
26 bit IN FALSE hm2_7i97.0.encoder.01.latch-polarity
26 float OUT 0 hm2_7i97.0.encoder.01.position
26 float OUT 0 hm2_7i97.0.encoder.01.position-latched
26 bit OUT FALSE hm2_7i97.0.encoder.01.quad-error
26 bit IN FALSE hm2_7i97.0.encoder.01.quad-error-enable
26 s32 OUT 0 hm2_7i97.0.encoder.01.rawcounts
26 s32 OUT 0 hm2_7i97.0.encoder.01.rawlatch
26 bit IN FALSE hm2_7i97.0.encoder.01.reset
26 float OUT 0 hm2_7i97.0.encoder.01.velocity
26 float OUT 0 hm2_7i97.0.encoder.01.velocity-rpm
26 s32 OUT 0 hm2_7i97.0.encoder.02.count
26 s32 OUT 0 hm2_7i97.0.encoder.02.count-latched
26 bit I/O FALSE hm2_7i97.0.encoder.02.index-enable
26 bit OUT FALSE hm2_7i97.0.encoder.02.input-a
26 bit OUT TRUE hm2_7i97.0.encoder.02.input-b
26 bit OUT FALSE hm2_7i97.0.encoder.02.input-index
26 bit IN FALSE hm2_7i97.0.encoder.02.latch-enable
26 bit IN FALSE hm2_7i97.0.encoder.02.latch-polarity
26 float OUT 0 hm2_7i97.0.encoder.02.position
26 float OUT 0 hm2_7i97.0.encoder.02.position-latched
26 bit OUT FALSE hm2_7i97.0.encoder.02.quad-error
26 bit IN FALSE hm2_7i97.0.encoder.02.quad-error-enable
26 s32 OUT 1 hm2_7i97.0.encoder.02.rawcounts
26 s32 OUT 1 hm2_7i97.0.encoder.02.rawlatch
26 bit IN FALSE hm2_7i97.0.encoder.02.reset
26 float OUT 0 hm2_7i97.0.encoder.02.velocity
26 float OUT 0 hm2_7i97.0.encoder.02.velocity-rpm
26 s32 OUT 0 hm2_7i97.0.encoder.03.count
26 s32 OUT 0 hm2_7i97.0.encoder.03.count-latched
26 bit I/O FALSE hm2_7i97.0.encoder.03.index-enable
26 bit OUT TRUE hm2_7i97.0.encoder.03.input-a
26 bit OUT TRUE hm2_7i97.0.encoder.03.input-b
26 bit OUT TRUE hm2_7i97.0.encoder.03.input-index
26 bit IN FALSE hm2_7i97.0.encoder.03.latch-enable
26 bit IN FALSE hm2_7i97.0.encoder.03.latch-polarity
26 float OUT 0 hm2_7i97.0.encoder.03.position
26 float OUT 0 hm2_7i97.0.encoder.03.position-latched
26 bit OUT FALSE hm2_7i97.0.encoder.03.quad-error
26 bit IN FALSE hm2_7i97.0.encoder.03.quad-error-enable
26 s32 OUT 0 hm2_7i97.0.encoder.03.rawcounts
26 s32 OUT 0 hm2_7i97.0.encoder.03.rawlatch
26 bit IN FALSE hm2_7i97.0.encoder.03.reset
26 float OUT 0 hm2_7i97.0.encoder.03.velocity
26 float OUT 0 hm2_7i97.0.encoder.03.velocity-rpm
26 s32 OUT 0 hm2_7i97.0.encoder.04.count
26 s32 OUT 0 hm2_7i97.0.encoder.04.count-latched
26 bit I/O FALSE hm2_7i97.0.encoder.04.index-enable
26 bit OUT FALSE hm2_7i97.0.encoder.04.input-a
26 bit OUT FALSE hm2_7i97.0.encoder.04.input-b
26 bit OUT TRUE hm2_7i97.0.encoder.04.input-index
26 bit IN FALSE hm2_7i97.0.encoder.04.latch-enable
26 bit IN FALSE hm2_7i97.0.encoder.04.latch-polarity
26 float OUT 0 hm2_7i97.0.encoder.04.position
26 float OUT 0 hm2_7i97.0.encoder.04.position-latched
26 bit OUT FALSE hm2_7i97.0.encoder.04.quad-error
26 bit IN FALSE hm2_7i97.0.encoder.04.quad-error-enable
26 s32 OUT 0 hm2_7i97.0.encoder.04.rawcounts
26 s32 OUT 0 hm2_7i97.0.encoder.04.rawlatch
26 bit IN FALSE hm2_7i97.0.encoder.04.reset
26 float OUT 0 hm2_7i97.0.encoder.04.velocity
26 float OUT 0 hm2_7i97.0.encoder.04.velocity-rpm
26 s32 OUT 0 hm2_7i97.0.encoder.05.count
26 s32 OUT 0 hm2_7i97.0.encoder.05.count-latched
26 bit I/O FALSE hm2_7i97.0.encoder.05.index-enable
26 bit OUT TRUE hm2_7i97.0.encoder.05.input-a
26 bit OUT FALSE hm2_7i97.0.encoder.05.input-b
26 bit OUT FALSE hm2_7i97.0.encoder.05.input-index
26 bit IN FALSE hm2_7i97.0.encoder.05.latch-enable
26 bit IN FALSE hm2_7i97.0.encoder.05.latch-polarity
26 float OUT 0 hm2_7i97.0.encoder.05.position
26 float OUT 0 hm2_7i97.0.encoder.05.position-latched
26 bit OUT FALSE hm2_7i97.0.encoder.05.quad-error
26 bit IN FALSE hm2_7i97.0.encoder.05.quad-error-enable
26 s32 OUT 1 hm2_7i97.0.encoder.05.rawcounts
26 s32 OUT 1 hm2_7i97.0.encoder.05.rawlatch
26 bit IN FALSE hm2_7i97.0.encoder.05.reset
26 float OUT 0 hm2_7i97.0.encoder.05.velocity
26 float OUT 0 hm2_7i97.0.encoder.05.velocity-rpm
26 bit IN FALSE hm2_7i97.0.encoder.hires-timestamp
26 u32 IN 0x007F2815 hm2_7i97.0.encoder.muxed-sample-frequency
26 u32 IN 0x00000000 hm2_7i97.0.encoder.muxed-skew
26 s32 IN -1 hm2_7i97.0.encoder.timer-number
26 bit OUT TRUE hm2_7i97.0.gpio.000.in
26 bit OUT FALSE hm2_7i97.0.gpio.000.in_not
26 bit IN FALSE hm2_7i97.0.gpio.000.out
26 bit OUT TRUE hm2_7i97.0.gpio.001.in
26 bit OUT FALSE hm2_7i97.0.gpio.001.in_not
26 bit IN FALSE hm2_7i97.0.gpio.001.out
26 bit OUT TRUE hm2_7i97.0.gpio.002.in
26 bit OUT FALSE hm2_7i97.0.gpio.002.in_not
26 bit IN FALSE hm2_7i97.0.gpio.002.out
26 bit OUT TRUE hm2_7i97.0.gpio.003.in
26 bit OUT FALSE hm2_7i97.0.gpio.003.in_not
26 bit IN FALSE hm2_7i97.0.gpio.003.out
26 bit OUT TRUE hm2_7i97.0.gpio.004.in
26 bit OUT FALSE hm2_7i97.0.gpio.004.in_not
26 bit IN FALSE hm2_7i97.0.gpio.004.out
26 bit OUT TRUE hm2_7i97.0.gpio.005.in
26 bit OUT FALSE hm2_7i97.0.gpio.005.in_not
26 bit IN FALSE hm2_7i97.0.gpio.005.out
26 bit OUT TRUE hm2_7i97.0.gpio.006.in
26 bit OUT FALSE hm2_7i97.0.gpio.006.in_not
26 bit IN FALSE hm2_7i97.0.gpio.006.out
26 bit OUT TRUE hm2_7i97.0.gpio.007.in
26 bit OUT FALSE hm2_7i97.0.gpio.007.in_not
26 bit IN FALSE hm2_7i97.0.gpio.007.out
26 bit OUT TRUE hm2_7i97.0.gpio.008.in
26 bit OUT FALSE hm2_7i97.0.gpio.008.in_not
26 bit IN FALSE hm2_7i97.0.gpio.008.out
26 bit OUT TRUE hm2_7i97.0.gpio.009.in
26 bit OUT FALSE hm2_7i97.0.gpio.009.in_not
26 bit OUT TRUE hm2_7i97.0.gpio.010.in
26 bit OUT FALSE hm2_7i97.0.gpio.010.in_not
26 bit OUT TRUE hm2_7i97.0.gpio.011.in
26 bit OUT FALSE hm2_7i97.0.gpio.011.in_not
26 bit OUT FALSE hm2_7i97.0.gpio.012.in
26 bit OUT FALSE hm2_7i97.0.gpio.012.in_not
26 bit OUT TRUE hm2_7i97.0.gpio.013.in
26 bit OUT FALSE hm2_7i97.0.gpio.013.in_not
26 bit OUT FALSE hm2_7i97.0.gpio.014.in
26 bit OUT TRUE hm2_7i97.0.gpio.014.in_not
26 bit OUT TRUE hm2_7i97.0.gpio.015.in
26 bit OUT FALSE hm2_7i97.0.gpio.015.in_not
26 bit OUT FALSE hm2_7i97.0.gpio.016.in
26 bit OUT TRUE hm2_7i97.0.gpio.016.in_not
26 bit OUT TRUE hm2_7i97.0.gpio.017.in
26 bit OUT FALSE hm2_7i97.0.gpio.017.in_not
26 bit OUT TRUE hm2_7i97.0.gpio.018.in
26 bit OUT FALSE hm2_7i97.0.gpio.018.in_not
26 bit OUT FALSE hm2_7i97.0.gpio.019.in
26 bit OUT TRUE hm2_7i97.0.gpio.019.in_not
26 bit OUT FALSE hm2_7i97.0.gpio.020.in
26 bit OUT TRUE hm2_7i97.0.gpio.020.in_not
26 bit OUT FALSE hm2_7i97.0.gpio.021.in
26 bit OUT TRUE hm2_7i97.0.gpio.021.in_not
26 bit OUT FALSE hm2_7i97.0.gpio.022.in
26 bit OUT TRUE hm2_7i97.0.gpio.022.in_not
26 bit OUT FALSE hm2_7i97.0.gpio.023.in
26 bit OUT TRUE hm2_7i97.0.gpio.023.in_not
26 bit OUT FALSE hm2_7i97.0.gpio.024.in
26 bit OUT TRUE hm2_7i97.0.gpio.024.in_not
26 bit OUT FALSE hm2_7i97.0.gpio.025.in
26 bit OUT TRUE hm2_7i97.0.gpio.025.in_not
26 bit OUT FALSE hm2_7i97.0.gpio.026.in
26 bit OUT TRUE hm2_7i97.0.gpio.026.in_not
26 bit OUT FALSE hm2_7i97.0.gpio.027.in
26 bit OUT TRUE hm2_7i97.0.gpio.027.in_not
26 bit OUT FALSE hm2_7i97.0.gpio.028.in
26 bit OUT TRUE hm2_7i97.0.gpio.028.in_not
26 bit OUT TRUE hm2_7i97.0.gpio.029.in
26 bit OUT FALSE hm2_7i97.0.gpio.029.in_not
26 bit OUT TRUE hm2_7i97.0.gpio.030.in
26 bit OUT FALSE hm2_7i97.0.gpio.030.in_not
26 bit OUT TRUE hm2_7i97.0.gpio.031.in
26 bit OUT FALSE hm2_7i97.0.gpio.031.in_not
26 bit OUT TRUE hm2_7i97.0.gpio.032.in
26 bit OUT FALSE hm2_7i97.0.gpio.032.in_not
26 bit OUT FALSE hm2_7i97.0.gpio.033.in
26 bit OUT TRUE hm2_7i97.0.gpio.033.in_not
26 bit OUT TRUE hm2_7i97.0.gpio.034.in
26 bit OUT FALSE hm2_7i97.0.gpio.034.in_not
26 bit IN FALSE hm2_7i97.0.gpio.034.out
26 bit OUT TRUE hm2_7i97.0.gpio.035.in
26 bit OUT FALSE hm2_7i97.0.gpio.035.in_not
26 bit IN FALSE hm2_7i97.0.gpio.035.out
26 bit OUT TRUE hm2_7i97.0.gpio.036.in
26 bit OUT FALSE hm2_7i97.0.gpio.036.in_not
26 bit IN FALSE hm2_7i97.0.gpio.036.out
26 bit OUT TRUE hm2_7i97.0.gpio.037.in
26 bit OUT FALSE hm2_7i97.0.gpio.037.in_not
26 bit IN FALSE hm2_7i97.0.gpio.037.out
26 bit OUT TRUE hm2_7i97.0.gpio.038.in
26 bit OUT FALSE hm2_7i97.0.gpio.038.in_not
26 bit IN FALSE hm2_7i97.0.gpio.038.out
26 bit OUT TRUE hm2_7i97.0.gpio.039.in
26 bit OUT FALSE hm2_7i97.0.gpio.039.in_not
26 bit IN FALSE hm2_7i97.0.gpio.039.out
26 bit OUT TRUE hm2_7i97.0.gpio.040.in
26 bit OUT FALSE hm2_7i97.0.gpio.040.in_not
26 bit IN FALSE hm2_7i97.0.gpio.040.out
26 bit OUT TRUE hm2_7i97.0.gpio.041.in
26 bit OUT FALSE hm2_7i97.0.gpio.041.in_not
26 bit IN FALSE hm2_7i97.0.gpio.041.out
26 bit OUT TRUE hm2_7i97.0.gpio.042.in
26 bit OUT FALSE hm2_7i97.0.gpio.042.in_not
26 bit IN FALSE hm2_7i97.0.gpio.042.out
26 bit OUT TRUE hm2_7i97.0.gpio.043.in
26 bit OUT FALSE hm2_7i97.0.gpio.043.in_not
26 bit IN FALSE hm2_7i97.0.gpio.043.out
26 bit OUT TRUE hm2_7i97.0.gpio.044.in
26 bit OUT FALSE hm2_7i97.0.gpio.044.in_not
26 bit IN FALSE hm2_7i97.0.gpio.044.out
26 bit OUT TRUE hm2_7i97.0.gpio.045.in
26 bit OUT FALSE hm2_7i97.0.gpio.045.in_not
26 bit IN FALSE hm2_7i97.0.gpio.045.out
26 bit OUT TRUE hm2_7i97.0.gpio.046.in
26 bit OUT FALSE hm2_7i97.0.gpio.046.in_not
26 bit IN FALSE hm2_7i97.0.gpio.046.out
26 bit OUT TRUE hm2_7i97.0.gpio.047.in
26 bit OUT FALSE hm2_7i97.0.gpio.047.in_not
26 bit IN FALSE hm2_7i97.0.gpio.047.out
26 bit OUT TRUE hm2_7i97.0.gpio.048.in
26 bit OUT FALSE hm2_7i97.0.gpio.048.in_not
26 bit IN FALSE hm2_7i97.0.gpio.048.out
26 bit OUT TRUE hm2_7i97.0.gpio.049.in
26 bit OUT FALSE hm2_7i97.0.gpio.049.in_not
26 bit IN FALSE hm2_7i97.0.gpio.049.out
26 bit OUT TRUE hm2_7i97.0.gpio.050.in
26 bit OUT FALSE hm2_7i97.0.gpio.050.in_not
26 bit IN FALSE hm2_7i97.0.gpio.050.out
26 s32 OUT 0 hm2_7i97.0.inmux.00.enc0-count
26 s32 OUT -1 hm2_7i97.0.inmux.00.enc1-count
26 s32 OUT 0 hm2_7i97.0.inmux.00.enc2-count
26 s32 OUT 0 hm2_7i97.0.inmux.00.enc3-count
26 bit OUT FALSE hm2_7i97.0.inmux.00.input-00
26 bit OUT TRUE hm2_7i97.0.inmux.00.input-00-not
26 bit IN FALSE hm2_7i97.0.inmux.00.input-00-slow
26 bit OUT FALSE hm2_7i97.0.inmux.00.input-01
26 bit OUT TRUE hm2_7i97.0.inmux.00.input-01-not
26 bit IN FALSE hm2_7i97.0.inmux.00.input-01-slow
26 bit OUT FALSE hm2_7i97.0.inmux.00.input-02
26 bit OUT TRUE hm2_7i97.0.inmux.00.input-02-not
26 bit IN FALSE hm2_7i97.0.inmux.00.input-02-slow
26 bit OUT FALSE hm2_7i97.0.inmux.00.input-03
26 bit OUT TRUE hm2_7i97.0.inmux.00.input-03-not
26 bit IN FALSE hm2_7i97.0.inmux.00.input-03-slow
26 bit OUT FALSE hm2_7i97.0.inmux.00.input-04
26 bit OUT TRUE hm2_7i97.0.inmux.00.input-04-not
26 bit IN FALSE hm2_7i97.0.inmux.00.input-04-slow
26 bit OUT FALSE hm2_7i97.0.inmux.00.input-05
26 bit OUT TRUE hm2_7i97.0.inmux.00.input-05-not
26 bit IN FALSE hm2_7i97.0.inmux.00.input-05-slow
26 bit OUT FALSE hm2_7i97.0.inmux.00.input-06
26 bit OUT TRUE hm2_7i97.0.inmux.00.input-06-not
26 bit IN FALSE hm2_7i97.0.inmux.00.input-06-slow
26 bit OUT FALSE hm2_7i97.0.inmux.00.input-07
26 bit OUT TRUE hm2_7i97.0.inmux.00.input-07-not
26 bit IN FALSE hm2_7i97.0.inmux.00.input-07-slow
26 bit OUT FALSE hm2_7i97.0.inmux.00.input-08
26 bit OUT TRUE hm2_7i97.0.inmux.00.input-08-not
26 bit IN FALSE hm2_7i97.0.inmux.00.input-08-slow
26 bit OUT FALSE hm2_7i97.0.inmux.00.input-09
26 bit OUT TRUE hm2_7i97.0.inmux.00.input-09-not
26 bit IN FALSE hm2_7i97.0.inmux.00.input-09-slow
26 bit OUT TRUE hm2_7i97.0.inmux.00.input-10
26 bit OUT FALSE hm2_7i97.0.inmux.00.input-10-not
26 bit IN FALSE hm2_7i97.0.inmux.00.input-10-slow
26 bit OUT FALSE hm2_7i97.0.inmux.00.input-11
26 bit OUT TRUE hm2_7i97.0.inmux.00.input-11-not
26 bit IN FALSE hm2_7i97.0.inmux.00.input-11-slow
26 bit OUT FALSE hm2_7i97.0.inmux.00.input-12
26 bit OUT TRUE hm2_7i97.0.inmux.00.input-12-not
26 bit IN FALSE hm2_7i97.0.inmux.00.input-12-slow
26 bit OUT FALSE hm2_7i97.0.inmux.00.input-13
26 bit OUT TRUE hm2_7i97.0.inmux.00.input-13-not
26 bit IN FALSE hm2_7i97.0.inmux.00.input-13-slow
26 bit OUT FALSE hm2_7i97.0.inmux.00.input-14
26 bit OUT TRUE hm2_7i97.0.inmux.00.input-14-not
26 bit IN FALSE hm2_7i97.0.inmux.00.input-14-slow
26 bit OUT FALSE hm2_7i97.0.inmux.00.input-15
26 bit OUT TRUE hm2_7i97.0.inmux.00.input-15-not
26 bit IN FALSE hm2_7i97.0.inmux.00.input-15-slow
26 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-00
26 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-00-not
26 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-01
26 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-01-not
26 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-02
26 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-02-not
26 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-03
26 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-03-not
26 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-04
26 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-04-not
26 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-05
26 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-05-not
26 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-06
26 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-06-not
26 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-07
26 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-07-not
26 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-08
26 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-08-not
26 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-09
26 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-09-not
26 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-10
26 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-10-not
26 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-11
26 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-11-not
26 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-12
26 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-12-not
26 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-13
26 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-13-not
26 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-14
26 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-14-not
26 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-15
26 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-15-not
26 bit IN FALSE hm2_7i97.0.led.CR01
26 bit IN FALSE hm2_7i97.0.led.CR02
26 bit IN FALSE hm2_7i97.0.led.CR03
26 bit IN FALSE hm2_7i97.0.led.CR04
26 bit OUT FALSE hm2_7i97.0.packet-error
26 bit OUT FALSE hm2_7i97.0.packet-error-exceeded
26 s32 OUT 0 hm2_7i97.0.packet-error-level
26 s32 OUT 0 hm2_7i97.0.read-request.time
26 s32 OUT 459088 hm2_7i97.0.read.time
26 u32 OUT 0x00000000 hm2_7i97.0.sserial.port-0.fault-count
26 u32 OUT 0x00000003 hm2_7i97.0.sserial.port-0.port_state
26 u32 OUT 0x00000000 hm2_7i97.0.sserial.port-0.port_state2
26 u32 OUT 0x00000000 hm2_7i97.0.sserial.port-0.port_state3
26 bit IN TRUE hm2_7i97.0.sserial.port-0.run
26 bit IN FALSE hm2_7i97.0.ssr.00.out-00
26 bit IN FALSE hm2_7i97.0.ssr.00.out-01
26 bit IN FALSE hm2_7i97.0.ssr.00.out-02
26 bit IN FALSE hm2_7i97.0.ssr.00.out-03
26 bit IN FALSE hm2_7i97.0.ssr.00.out-04
26 bit IN FALSE hm2_7i97.0.ssr.00.out-05
26 u32 IN 0x000F4240 hm2_7i97.0.ssr.00.rate
26 bit I/O FALSE hm2_7i97.0.watchdog.has_bit
26 s32 OUT 47718 hm2_7i97.0.write.time
Pin Aliases:
Alias Original Name
Signals:
Type Value Name (linked to)
Parameters:
26 float RW 1 hm2_7i97.0.8i20.0.0.angle-maxlim
26 float RW 0 hm2_7i97.0.8i20.0.0.angle-minlim
26 float RW 1 hm2_7i97.0.8i20.0.0.angle-scalemax
26 float RW 655.35 hm2_7i97.0.8i20.0.0.bus-voltage-scalemax
26 float RW 65535 hm2_7i97.0.8i20.0.0.card-temp-scalemax
26 float RW 30 hm2_7i97.0.8i20.0.0.current-maxlim
26 float RW -30 hm2_7i97.0.8i20.0.0.current-minlim
26 float RW 30 hm2_7i97.0.8i20.0.0.current-scalemax
26 u32 RW 0x000088B8 hm2_7i97.0.8i20.0.0.nvbrakeoffv
26 u32 RW 0x00009088 hm2_7i97.0.8i20.0.0.nvbrakeonv
26 u32 RW 0x00009664 hm2_7i97.0.8i20.0.0.nvbusoverv
26 u32 RW 0x00001194 hm2_7i97.0.8i20.0.0.nvbusundervmax
26 u32 RW 0x00000DAC hm2_7i97.0.8i20.0.0.nvbusundervmin
26 u32 RW 0x00000000 hm2_7i97.0.8i20.0.0.nvkdihi
26 u32 RW 0x00007D00 hm2_7i97.0.8i20.0.0.nvkdil
26 u32 RW 0x0000C350 hm2_7i97.0.8i20.0.0.nvkdilo
26 u32 RW 0x00000032 hm2_7i97.0.8i20.0.0.nvkdp
26 u32 RW 0x00000000 hm2_7i97.0.8i20.0.0.nvkqihi
26 u32 RW 0x00007D00 hm2_7i97.0.8i20.0.0.nvkqil
26 u32 RW 0x0000C350 hm2_7i97.0.8i20.0.0.nvkqilo
26 u32 RW 0x00000032 hm2_7i97.0.8i20.0.0.nvkqp
26 u32 RW 0x000002EE hm2_7i97.0.8i20.0.0.nvmaxcurrent
26 u32 RW 0x00000009 hm2_7i97.0.8i20.0.0.nvrembaudrate
26 u32 RO 0x0000008B hm2_7i97.0.8i20.0.0.swrevision
26 u32 RO 0x0A000112 hm2_7i97.0.8i20.0.0.unitnumber
26 bit RW FALSE hm2_7i97.0.encoder.00.counter-mode
26 bit RW TRUE hm2_7i97.0.encoder.00.filter
26 bit RW FALSE hm2_7i97.0.encoder.00.index-invert
26 bit RW TRUE hm2_7i97.0.encoder.00.index-mask
26 bit RW FALSE hm2_7i97.0.encoder.00.index-mask-invert
26 float RW 1000 hm2_7i97.0.encoder.00.scale
26 bit RW FALSE hm2_7i97.0.encoder.00.sel0.invert_output
26 bit RW FALSE hm2_7i97.0.encoder.00.sel0.is_opendrain
26 float RW 0.5 hm2_7i97.0.encoder.00.vel-timeout
26 bit RW FALSE hm2_7i97.0.encoder.01.counter-mode
26 bit RW TRUE hm2_7i97.0.encoder.01.filter
26 bit RW FALSE hm2_7i97.0.encoder.01.index-invert
26 bit RW FALSE hm2_7i97.0.encoder.01.index-mask
26 bit RW FALSE hm2_7i97.0.encoder.01.index-mask-invert
26 float RW 1 hm2_7i97.0.encoder.01.scale
26 float RW 0.5 hm2_7i97.0.encoder.01.vel-timeout
26 bit RW FALSE hm2_7i97.0.encoder.02.counter-mode
26 bit RW TRUE hm2_7i97.0.encoder.02.filter
26 bit RW FALSE hm2_7i97.0.encoder.02.index-invert
26 bit RW FALSE hm2_7i97.0.encoder.02.index-mask
26 bit RW FALSE hm2_7i97.0.encoder.02.index-mask-invert
26 float RW 1 hm2_7i97.0.encoder.02.scale
26 float RW 0.5 hm2_7i97.0.encoder.02.vel-timeout
26 bit RW FALSE hm2_7i97.0.encoder.03.counter-mode
26 bit RW TRUE hm2_7i97.0.encoder.03.filter
26 bit RW FALSE hm2_7i97.0.encoder.03.index-invert
26 bit RW FALSE hm2_7i97.0.encoder.03.index-mask
26 bit RW FALSE hm2_7i97.0.encoder.03.index-mask-invert
26 float RW 1 hm2_7i97.0.encoder.03.scale
26 float RW 0.5 hm2_7i97.0.encoder.03.vel-timeout
26 bit RW FALSE hm2_7i97.0.encoder.04.counter-mode
26 bit RW TRUE hm2_7i97.0.encoder.04.filter
26 bit RW FALSE hm2_7i97.0.encoder.04.index-invert
26 bit RW FALSE hm2_7i97.0.encoder.04.index-mask
26 bit RW FALSE hm2_7i97.0.encoder.04.index-mask-invert
26 float RW 1 hm2_7i97.0.encoder.04.scale
26 float RW 0.5 hm2_7i97.0.encoder.04.vel-timeout
26 bit RW FALSE hm2_7i97.0.encoder.05.counter-mode
26 bit RW TRUE hm2_7i97.0.encoder.05.filter
26 bit RW FALSE hm2_7i97.0.encoder.05.index-invert
26 bit RW FALSE hm2_7i97.0.encoder.05.index-mask
26 bit RW FALSE hm2_7i97.0.encoder.05.index-mask-invert
26 float RW 1 hm2_7i97.0.encoder.05.scale
26 float RW 0.5 hm2_7i97.0.encoder.05.vel-timeout
26 bit RW FALSE hm2_7i97.0.gpio.000.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.000.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.000.is_output
26 bit RW FALSE hm2_7i97.0.gpio.001.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.001.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.001.is_output
26 bit RW FALSE hm2_7i97.0.gpio.002.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.002.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.002.is_output
26 bit RW FALSE hm2_7i97.0.gpio.003.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.003.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.003.is_output
26 bit RW FALSE hm2_7i97.0.gpio.004.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.004.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.004.is_output
26 bit RW FALSE hm2_7i97.0.gpio.005.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.005.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.005.is_output
26 bit RW FALSE hm2_7i97.0.gpio.006.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.006.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.006.is_output
26 bit RW FALSE hm2_7i97.0.gpio.007.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.007.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.007.is_output
26 bit RW FALSE hm2_7i97.0.gpio.008.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.008.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.008.is_output
26 bit RW FALSE hm2_7i97.0.gpio.019.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.019.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.020.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.020.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.021.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.021.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.022.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.022.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.023.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.023.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.024.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.024.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.025.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.025.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.026.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.026.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.027.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.027.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.028.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.028.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.029.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.029.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.034.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.034.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.034.is_output
26 bit RW FALSE hm2_7i97.0.gpio.035.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.035.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.035.is_output
26 bit RW FALSE hm2_7i97.0.gpio.036.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.036.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.036.is_output
26 bit RW FALSE hm2_7i97.0.gpio.037.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.037.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.037.is_output
26 bit RW FALSE hm2_7i97.0.gpio.038.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.038.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.038.is_output
26 bit RW FALSE hm2_7i97.0.gpio.039.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.039.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.039.is_output
26 bit RW FALSE hm2_7i97.0.gpio.040.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.040.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.040.is_output
26 bit RW FALSE hm2_7i97.0.gpio.041.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.041.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.041.is_output
26 bit RW FALSE hm2_7i97.0.gpio.042.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.042.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.042.is_output
26 bit RW FALSE hm2_7i97.0.gpio.043.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.043.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.043.is_output
26 bit RW FALSE hm2_7i97.0.gpio.044.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.044.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.044.is_output
26 bit RW FALSE hm2_7i97.0.gpio.045.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.045.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.045.is_output
26 bit RW FALSE hm2_7i97.0.gpio.046.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.046.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.046.is_output
26 bit RW FALSE hm2_7i97.0.gpio.047.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.047.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.047.is_output
26 bit RW FALSE hm2_7i97.0.gpio.048.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.048.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.048.is_output
26 bit RW FALSE hm2_7i97.0.gpio.049.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.049.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.049.is_output
26 bit RW FALSE hm2_7i97.0.gpio.050.invert_output
26 bit RW FALSE hm2_7i97.0.gpio.050.is_opendrain
26 bit RW FALSE hm2_7i97.0.gpio.050.is_output
26 bit RW FALSE hm2_7i97.0.inmux.00.enc0_4xmode
26 bit RW FALSE hm2_7i97.0.inmux.00.enc1_4xmode
26 bit RW FALSE hm2_7i97.0.inmux.00.enc2_4xmode
26 bit RW FALSE hm2_7i97.0.inmux.00.enc3_4xmode
26 u32 RW 0x00000005 hm2_7i97.0.inmux.00.fast_scans
26 u32 RW 0x00004E20 hm2_7i97.0.inmux.00.scan_rate
26 u32 RO 0x00000010 hm2_7i97.0.inmux.00.scan_width
26 u32 RW 0x000001F4 hm2_7i97.0.inmux.00.slow_scans
26 bit RW FALSE hm2_7i97.0.io_error
26 s32 RO 1 hm2_7i97.0.packet-error-decrement
26 s32 RW 2 hm2_7i97.0.packet-error-increment
26 s32 RW 10 hm2_7i97.0.packet-error-limit
26 s32 RW 80 hm2_7i97.0.packet-read-timeout
26 s32 RW 0 hm2_7i97.0.read-request.tmax
26 bit RO FALSE hm2_7i97.0.read-request.tmax-increased
26 s32 RW 765220 hm2_7i97.0.read.tmax
26 bit RO FALSE hm2_7i97.0.read.tmax-increased
26 bit RW FALSE hm2_7i97.0.sserial.00.tx0.invert_output
26 bit RW FALSE hm2_7i97.0.sserial.00.tx0.is_opendrain
26 bit RW FALSE hm2_7i97.0.sserial.00.txen0.invert_output
26 bit RW FALSE hm2_7i97.0.sserial.00.txen0.is_opendrain
26 u32 RW 0x00000001 hm2_7i97.0.sserial.port-0.fault-dec
26 u32 RW 0x0000000A hm2_7i97.0.sserial.port-0.fault-inc
26 u32 RW 0x000000C8 hm2_7i97.0.sserial.port-0.fault-lim
26 u32 RW 0x004C4B40 hm2_7i97.0.watchdog.timeout_ns
26 s32 RW 143085 hm2_7i97.0.write.tmax
26 bit RO FALSE hm2_7i97.0.write.tmax-increased
Parameter Aliases:
Alias Original Name
hm2_7i97.0.encoder.00.sel0.invert_output hm2_7i97.0.gpio.018.invert_output
hm2_7i97.0.encoder.00.sel0.is_opendrain hm2_7i97.0.gpio.018.is_opendrain
hm2_7i97.0.sserial.00.tx0.invert_output hm2_7i97.0.gpio.032.invert_output
hm2_7i97.0.sserial.00.tx0.is_opendrain hm2_7i97.0.gpio.032.is_opendrain
hm2_7i97.0.sserial.00.txen0.invert_output hm2_7i97.0.gpio.033.invert_output
hm2_7i97.0.sserial.00.txen0.is_opendrain hm2_7i97.0.gpio.033.is_opendrain
Exported Functions:
Owner CodeAddr Arg FP Users Name
00026 7fa9b1d0d8b5 55d6afc75b20 YES 1 hm2_7i97.0.read
00026 7fa9b1d0d841 55d6afc75b20 YES 0 hm2_7i97.0.read-request
00026 7fa9b1d0d709 55d6afc75b20 YES 1 hm2_7i97.0.write
Realtime Threads:
Period FP Name ( Time, Max-Time )
Also my guess is that the stall current listed on the motor nameplate
is the continuous stall current, not the peak current. So its likely
that you would need to set the 8I20s peak current to 20 or 30 A
(2000 or 3000) to get the full potential torque from the motor
Yeah wondered that too, just tried to play safe for testing at 7.5a image missing /media/kunena/emoticons/smile.png
3 years 10 months ago #259863 by PCW
OK
what does:
halcmd -kf
halcmd: unlinkp hm2_7i97.0.8i20.0.0.current
halcmd: setp hm2_7i97.0.8i20.0.0.current 5
do? does it cause motor motion (or detent torque)
(the "halcmd: " is a prompt, don't type it)
3 years 10 months ago #259864 by saquzi
Tried that, it caused the servo to move :) and can turn it with hand, will "locate" itself in every 90degrees apart.
3 years 10 months ago #259866 by PCW
OK that means the 8i20 is enabled and working
so lack of motion is probably some problem(s)
with BLDC setup, either initialization or feedback
3 years 10 months ago #259894 by saquzi
guess initialization is not the problem now when trying to use only "f" mode?
3 years 10 months ago #259897 by PCW
Did you verify that the commutation angle changes from 0 to 1 when you rotate the motor shaft 0 to 90 degrees?
If the motor current is always 0, did you trace the commanded current back through
the PID component, its inputs and tuning setup pins?
Time to create page: 0.190 seconds
