- Thank you received: 5334
Issue with Mesa 5i25 - 7i76 configuration
3 years 5 months ago #272025
Replied by PCW on topic Issue with Mesa 5i25 - 7i76 configuration
Yes, that is what the 5VP pins are TB2 and TB3 are for.Can I connect it to the +5V of TB2 on the board?
The following user(s) said Thank You: Octave
3 years 5 months ago #272157
by Octave
Replied by Octave on topic Issue with Mesa 5i25 - 7i76 configuration
Hello,
thank you very much for all your responses.
I have modified the wiring of my drivers as you advised. That has already solved one problem, but there seems to be another one as the motors are not rotating.
I don't even have the impression that my 5I25 and 7I76 are communicating with each other. Is there a way to clarify this?
Do you have any other ideas about errors I might have made?
There are still photos showing the current state in a link from the first message of this thread. I am available to provide more details and photos.
3 years 5 months ago #272158
I notice in your picture of the 7I76, W2 is in the left-hand position
This is wrong if you are supplying 5V to the 7I76 power via TB3
(7I76 manual page 2)
A simple hardware sanity check is to run LinuxCNC and jog in both directions
and check that the associated DIR signals on TB2 change
3 years 5 months ago #272166
by Octave
Hello, there's no 5V alimentation on TB3 the only one i have is 12V on TB1 for I/O
Any suggestion ? Is there an error and should i change the position of W2 ? If not do you (all) have any other advice !
Thanks for your answer !
3 years 5 months ago #272167
OK I think I mixed that up with a different thread
I would leave it as it is and check that direction changes
as mentioned.
as mentioned.
Time to create page: 0.142 seconds
