Changes in configuration files generated in pncconfig for 7i76 to 7i78
10 months 2 weeks ago #340158 by PCW
7C81 configuration for 7I78 on P1, INM on first 12 P2 pins
The inm module supports up to 4 MPG encoders,
it also has built in input filtering/debouncing.
The last 5 P2 pins are left as GPIO so can be inputs/outputs
as needed
File Name: 7c81_7i78_inm.zip
File Size:105.62 KB
The following user(s) said Thank You: jaro_p
10 months 2 weeks ago #340178 by jaro_p
Thank you very much, you are great.
10 months 2 weeks ago #340275 by jaro_p
Unfortunately, the situation is anything but simple… I reinstalled Bookworm, but the command:
`sudo mesaflash --spi --addr /dev/spidev0.0 --device 7c81 --readhmid`
doesn't work:
- open: No such file or directory
- No 7C81 board found
The following works:
`halcmd -kf`
`halcmd: loadrt hostmot2`
`halcmd: loadrt hm2_rpspi`
`halcmd: show all hm2`
However, I don't know how to write a new bitfile. That is, the equivalent of:
`sudo mesaflash --spi --addr /dev/spidev0.0 --device 7c81 --fallback --write bitfile-name`
I tried installing an older version of LinuxCNC – Buster. However, the libraries for installing mesaflash are missing and cannot be installed because the repositories for this version no longer exist.
10 months 2 weeks ago #340278 by unknown
What is the result of
ls /dev/spidev*
10 months 2 weeks ago #340279 by jaro_p
cnc@raspberrypi:~$ ls /dev/spidev*
ls: cannot access '/dev/spidev*': No such file or directory
10 months 2 weeks ago #340282 by unknown
What RPi model are you using and what image are you using.
spi hasn't been enabled in config.txt
Time to create page: 0.453 seconds
