Configuration Problems 7i92 PnCConf
  • markbaenen
  • Topic Author
  • New Member
  • New Member
8 months 3 weeks ago #342669 by markbaenen
Configuration Problems 7i92 PnCConf was created by markbaenen
/homeI am not a dense person. I have read A LOT on configuring. I have set up a couple other machines with StepConf.
Why does this:
look absolutely nothing like this:
when trying to configure this:
8 months 3 weeks ago #342675 by PCW
Replied by PCW on topic Configuration Problems 7i92 PnCConf
Mesa configurations do not use pin numbers but channel numbers for things like stepgens and pwmgens
As long as you have the correct firmware, the order of these channels typically matches the breakout
For GPIO, GPIO numbers are used (the connector pin == GPIO mapping is in the readhmid printout)
  • markbaenen
  • Topic Author
  • New Member
  • New Member
8 months 3 weeks ago #342682 by markbaenen
Replied by markbaenen on topic Configuration Problems 7i92 PnCConf
What is the point of this config page? This has to be the least intuitive config thing I have ever seen.
8 months 3 weeks ago #342683 by PCW
The point is that for most configurations you don't deal with pin numbers at all,
just channel numbers, which is also consistent with the hal file function naming.
For GPIO (which is not much used on newer systems) it would be helpful if
pncconf listed the pin numbers at least for parallel port BOBs
  • markbaenen
  • Topic Author
  • New Member
  • New Member
8 months 3 weeks ago #342712 by markbaenen
So you are saying that if everything on the config page says "unused", it will still work?
8 months 3 weeks ago - 8 months 3 weeks ago #342713 by tommylight
Replied by tommylight on topic Configuration Problems 7i92 PnCConf
Yes, the config will work, but features might not.
You have to choose stepgens or PWMgens or encoders that you want to use, also pins for IO if needed.
Last edit: 8 months 3 weeks ago by tommylight. Reason: more info
  • markbaenen
  • Topic Author
  • New Member
  • New Member
8 months 3 weeks ago #342715 by markbaenen
Stepgens for 2-9 for axes. Where is two? Where is 10 thru 14?
8 months 3 weeks ago #342717 by PCW
Also you would typically configure P2 if you only have one breakout board
as that has the first stepgens and pwmgens,
Here's firmware that places the first stepgens and PWMgen on P1:
File Name: 7i92_5abobx2dr.zip
File Size:108.46 KB
(basically just reverses the connectors)  You would need to use
pncconfs "Discover" option to get it to display the correct
GPIO and channel numbers.
  • markbaenen
  • Topic Author
  • New Member
  • New Member
8 months 3 weeks ago #342722 by markbaenen
I wrote that firmware to the board.
I used the discovery option and accepted the component changes.
This still make zero sense:
  • markbaenen
  • Topic Author
  • New Member
  • New Member
8 months 3 weeks ago #342724 by markbaenen
Time to create page: 0.094 seconds
