Probe for center of hole
- Rick G
- Thank you received: 114
25 Mar 2012 10:39 #18775
by Rick G
Probe for center of hole was created by Rick G
Chris Radek has agreed to "re share" this neat sub to find the center of a hole and also list it's dimensions.
It can be found at...
timeguy.com/cradek/01262579508
It also looked like the perfect candidate to be added to ngcgui.
Rick G
Rick G
- Rick G
25 Mar 2012 10:45 #18776
by Rick G
Replied by Rick G on topic Re:Probe for center of hole
Here I have taken Chris Radek's hole center finding routine and modified it for ngcgui.
In the attached file the:
The g0 moves have been changed to g1 for the less adventurous.
Added correction fields for center location of hole.
Added correction field for x and y diameter.
Simply enter the proper information in the fields, jog the probe to a position inside the hole and go.
Rick G
Rick G
The following user(s) said Thank You: Tchefter
- BigJohnT
- Thank you received: 994
25 Mar 2012 12:15 #18779
by BigJohnT
Replied by BigJohnT on topic Re:Probe for center of hole
I can't wait to get the BP converted and make a probe for it...
- eneias_eringer
- Thank you received: 4
22 Apr 2012 23:22 #19447
by eneias_eringer
Replied by eneias_eringer on topic Re:Probe for center of hole
HI !!! am from Brasil , and i use your probe routine with some modifications of calibration, and i do one with 3 point center find look:::
Ps. Sorry my english.....
- Rick G
23 Apr 2012 11:15 #19453
by Rick G
Looks good!
Rick G
Rick G
- eneias_eringer
23 Apr 2012 11:43 #19455
by eneias_eringer
The routine:
- eneias_eringer
23 Apr 2012 11:45 #19456
by eneias_eringer
The calibration routine:
- Rick G
23 Apr 2012 13:59 #19464
by Rick G
Thanks for posting the files , I will have a look this weekend.
Rick G
Rick G
- eneias_eringer
23 Apr 2012 14:12 #19465
by eneias_eringer
Ok !!!
Thanks....
I will change the error compesation of center and diameter of stylus to Radius , i think i have problems with diameter correction ....
Thanks....
- eneias_eringer
23 Apr 2012 14:13 #19466
by eneias_eringer
And put more calibration points ( maybe 30-30 degrees like renishaw routine) ....
Time to create page: 0.274 seconds
