- Thank you received: 114
If you did not select a postamble then none is being used, the M2 is doing everything.I can't find the postamble that is being applied to my subs. I see the default preamble std-in.ngc, but there is a single line w/ two comments being appended to the file wit hthe M2
Change from Auto mode to MDI mode.
Origin offsets are set to the default (like G54).
Selected plane is set to XY plane (like G17).
Distance mode is set to absolute mode (like G90).
Feed rate mode is set to units per minute (like G94).
Feed and speed overrides are set to ON (like M48).
Cutter compensation is turned off (like G40).
The spindle is stopped (like M5).
The current motion mode is set to feed (like G1).
Coolant is turned off (like M9).
somenewguy wrote: ok I think I will continue to sit on 2.5.3, and wait for 2.5.4 to be released.
