- Thank you received: 994
fc60 wrote: Greetings John,
I will see if I can modify my Post to output the M02 at the end of the file.
Regarding the "%" symbols, it is best to erase both of them?
Also, the link you posted is dead. I get the Error 404, page not found.
With kind regards,
David
NGCGUI_PREAMBLE = in_std.ngc - the preamble file to be added in front of the subroutines. When concatenating several common subroutine invocations, this preamble is only added once. For mm-based machines, use mm_std.ngc
cncnoel wrote: My 2 cents worth..
Cent 1
I have been using a preamble subroutine file for a while now, so If I decide to change something I only need to do it in one place.
It is called from G-code with o<preamble> call
Cent 2
I LOVE using white space and # boxes 80 characters wide in G-code, it makes it so much easier to read for my old eyes!
comes from being a DOS dinosaur from the days of PCM and green-screen monitors... Sigh!
