M66 IF Request in Subroutine
2 years 11 months ago #286340 by MaHa
Replied by MaHa on topic M66 IF Request in Subroutine
g4 does only prevent axes from movement, for other, there is no effect. If you need a delay and increasing timeout does not work maybe try mcode,like:
#!/bin/bash sleep .5 exit 0
2 years 11 months ago #286345 by CNC_ANDI
My G4 P0.5 Works correct... the problem is the second if statement
2 years 11 months ago #286353 by rmu
Replied by rmu on topic M66 IF Request in Subroutine
so you say if you enter those commands in MDI it works but executing in one file it doesn't?
2 years 11 months ago - 2 years 11 months ago #286359 by CNC_ANDI
M66 P31 L3 Q1 ; check for drawbar
O104 if [#5399 LT 0]
(abort, failed drawbar not open)
O104 endif
M66 P29 L3 Q1 ; check for tool
O105 if [#5399 LT 0]
(abort, failed tool not clamped)
O105 endif
does not work. O105 dont write the parameter 5399 new
O105 endif
In a single file it works
O104 endif
Last edit: 2 years 11 months ago by CNC_ANDI.
2 years 11 months ago #286363 by rmu
ok you have to describe in detail what the signal levels are when, what is expected and what is happening. i checked the thread, you only say "it works" or "it doesn't work".
i'm pretty sure the variable is written like it should, so something else is going on.
2 years 11 months ago - 2 years 11 months ago #286365 by CNC_ANDI
when O104 is not ok then -1 will be written
when O104 is ok then +1 will be written
when O105 is not ok +1 is written
when O105 is ok +1 is written
the 2 sensor are ok when it changes to high
sensor 1 high ok drawbar is open
sensor 2 high ok tool is clamped
but the drawbar (sensor 1) most be close before i can check sensor 2 (clamped tool)
