Resize ngcgui tab contents in axis?
15 years 7 months ago #7607 by Pilotltd
BigJohnT wrote:
That is the ini setting. Look in the README file:
www.panix.com/~dgarrett/ngcgui/README
Look by the options section for font.
Also you need to make the Axis screen wider to see 11 and 12. There is a way in 10.04 I think to define the default screen size for axis but it escapes me at the moment.
Hi John - the ini file contains
NGCGUI_FONT = Sans -8 normal
The default was
NGCGUI_FONT = Helvetica -10 normal
the font options does absolutely nothing here. I can change the font size or type in the ini file without any effect whatsoever?
I thought the problem was because there is no helvetica font in Ubuntu 10.04, so I changed it to Sans (which does exist) and that does nothing either.
Can't make axis wider, that's full screen :(
Steve
15 years 7 months ago #7608 by Pilotltd
Got it - removing everything after NGCGUI_FONT =
works. That line has no option and now works - yipee :)
Time to create page: 0.269 seconds
